2000 Navy Blue- difficult to match?
Body Shop #1 tried to match it twice. The first time it was close, but there was a milky haze at the top of the bumper cover. I had paid $750 for the work and thought that it should be done again. The second time it came out too dark, discernible in any light, but easiest to see with overhead lights, as in my garage. Body shop #1 is thought to be the best in the area, and I had many mistakes repaired before. I was buffaloed as to why they couldn't match it, and just chalked it up to a fall off in their quality control.
This past winter I hit the same area again, trying to get out of my garage, hitting a huge bank of ice and snow at the entrance. I hadn't driven the car in 5 weeks, and I needed to give it a run.
This past week I brought it in to Body Shop 2, to fix the returned crack, and to re-shoot the bumper cover for a better match.
The price was much better, and I really liked the owner, who had a lot of high end work in his shop. Upon picking up the car today I was really disappointed again with the color match, which was virtually the same as the tone of the work as done by Body Shop #1, second attempt.
The car is 11 years old, perhaps the rest of the hood is faded? Or, maybe there is more than one formula for Navy Blue? Whatever the reason, I am 0 for 3 on this work- with first class shops, and I'm starting to think there is some trick to matching the color.
Does any body out there have any experience with matching this color?
Thanks,
Bluemill
Anyway...the point I wanted to make was....don't beat yourself up over worrying about the perfect match.
When I painted my Navy Blue front facsia, MCM hood and rear spoiler the match was nice. When I bought the car, it had some rock nicks on the head lamp covers and the tonneau cover from the top rubbing and the outfit I bought the car from had it those parts painted, nice match too. It's almost impossible to get a 100% match without painting the entire car-blending helps but even slight variations in metallic density can make it look different to the eye in different lights.
Most modern car finishes consist of a base coating that contains the color, topped with a protective clear coat that is designed to keep the pigmented paint from oxidizing. This outer clear coat adds UV protection that helps prevent the sun's rays from drying out the base paint. Oxidation was an obvious problem ten years ago because you quickly saw the color fade. Now that the outer layer is usually clear, oxidation is less obvious, YET IT STILL OCCURS. The sun dries out top paint layers and natural oils are lost. If these oils aren't replaced, the paint oxidizes and the surface gradually becomes duller and duller.
A very minimal ‘UV Package' is generally added to clear urethanes. Since most clear urethanes are applied over pigmented urethanes the manufacturers tend to let the pigments in the bottom coating perform the UV blocking, thus the fade.
Looking at the code on the glove compartment sticker, I did find a definite code number there.
Can anyone out there tell me what the code for the lighter formula Navy Blue is? -or by process of elimination, the code for the darker of the two codes?
Best,
Bluemill
Best,
Bluemill
Corrected: I found 2 paint codes used for '99 NBM. WA352E and WA353E but only one for '00. That's where the lighter shade may come in. For GM WA353E, the PPG # is 5387, Dupont is B9820 and S-W is 54694. Your best answer as to the light/dark difference will probably be to drop in to a S-W store and talk with them and bring their part numbers. I still think the paint is faded to a certain degree, even though it was garaged.
I had the same exact problem with '99 magnetic red, it's a metallic red. Car has always garaged, waxed, no repaint, never hit, no bodywork, no wet sand on the clear coat, ever, but it is under the Florida sun and the paint color, not the clearcoat, has faded somewhat from the original. I know what it looked like originally and now it's slightly more orange-ish than when the red was new. I see the difference inside the door jambs and if you look closely you may see yours too. Looks like your in MA, not FL but I still say the paint is not 100% the original shade and that's what body shops complain about all the time, that it's difficult to match aged paint. That's why they always want to paint much more than what's absolutely necessary.
Paint was a dead match the first attempt. We used Dupont Chroma Base, I had heard that the Dupont paint matches blues better and it did.
Mine is NBM also. But I removed it and re-installed it by myself. Not hard at all.
Gregg
I'm going back tomorrow to match it to the car.
Best,
Bluemill
