Keyless entry
Old Apr 20, 2011 | 11:00 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Default Keyless entry
The other day I had trouble with my (new to me) 99 vert. Anyway one of the things that fixed it was disconnecting the battery. Now the remote doesn't work. Strange because I have factory keyless remote on 5 other GM cars (03,01,00, 96 etc), and disconnecting the battery doesn't effect them. Untill I can get an owners manual and a 99 service manual does anybody have the sequence to reset?
Old Apr 20, 2011 | 12:46 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
last post here
http://forums.corvetteforum.com/c5-g...te-issues.html
My stupid remote works when it wants to
Old Apr 20, 2011 | 02:28 PM
markKlein's Avatar
markKlein
If I remember right you hold down the lock and unlock buttons for five seconds (standing next to the car of course). That should resync the fob and car. They often stop working when you disconnect the car battery becuase the system uses changing codes for tighter security, both the fob and car have to "change" at the same time; when you hook up the battery again, the car code might not match the fob.
Here's a PDF owners manual
http://www.gmpartshouse.com/download...99corvette.pdf
Old Apr 20, 2011 | 02:59 PM
cjlaw73's Avatar
cjlaw73
When I had to "reset" mine, you had to put the key in the ignition, turn it to on (not started), hold down the lock and unlock buttons simultaneously for about 5 to 10 seconds, and the car would beep to let you know it had been reset.
Old Apr 20, 2011 | 03:35 PM
zr1fred's Avatar
zr1fred
Great, thanks! Holding the two buttons down did the trick.
Old Apr 20, 2011 | 05:15 PM
cjlaw73's Avatar
cjlaw73
To Keyless entry
