Non run flats pressure?
Old Apr 21, 2011 | 08:00 AM
larrybee's Avatar
larrybee
Default Non run flats pressure?
Changed out w/non run flats. Would the recommended 30 psi cold still be good for non run flats??
Old Apr 21, 2011 | 08:10 AM
Should be no different than runflats. 30 psi will work fine.
Old Apr 21, 2011 | 08:34 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Since the sidewalls are not as stiff, I run 32 psi on the front tires.
Old Apr 21, 2011 | 08:36 AM
99 vett babycar's Avatar
99 vett babycar
non-run flates don't knowe they're non-run flates so 30 psi (or whatever you thought was best for your last set of tires ) should be a fine staring point.
Old Apr 21, 2011 | 09:13 AM
jrose7004's Avatar
jrose7004
30 psi cold.
Old Apr 21, 2011 | 11:33 AM
Tigershark3's Avatar
Tigershark3
the big three-oh - cold
Old Apr 21, 2011 | 11:51 AM
CBackous's Avatar
CBackous
:P
I do this as well. I started at 30psi cold, going up to 32 cold made it feel better in handling.
Old Apr 21, 2011 | 12:13 PM
Quicksilver Vert 01
It sure does.
Old Apr 21, 2011 | 03:14 PM
moserbe's Avatar
moserbe
Split the difference and go 31 psi.
Old Apr 21, 2011 | 07:24 PM
zagger's Avatar
zagger
Depending on tire speed rating and how you drive it but anything from 30 to 32 is fine. Some brands require higher pressure for high speed driving, check tire manufacturer recommendation for your tire model.
Old Apr 22, 2011 | 02:18 AM
Jistari's Avatar
Jistari
This comes up a lot. The reason they print the recommended pressure on the door in the car is they know how much the car weighs, which the tire manufacturer does not know (unless its a one off tire, specificaly for one car). Hence you dont rind "recommended" pressure on the tire (just max pressure). That info (the actual weight of the car) plus the oem tire size they have tested and found to perform well.
Its no big deal to go off the pressure on the door, but when in doubt, with most tires you should start there.
Old Apr 22, 2011 | 09:22 AM
rdline's Avatar
rdline
I run 32 on all four, runs smooth
Old Apr 22, 2011 | 11:59 AM
Marine One's Avatar
Marine One
I run 31 or 32 up front for the same reasons previously stated and 30 in the backs. I found that anything above 30 in the back tires will cause the centers to wear prematurely.
Old Apr 22, 2011 | 12:16 PM
Quicksilver Vert 01
And it also reduces traction.
Old Apr 22, 2011 | 01:23 PM
CBackous's Avatar
CBackous
What is this "traction" you speak of?
To Non run flats pressure?
