Oil pressure warning
Old Apr 22, 2011 | 11:52 PM
T-TOP TOM's Avatar
T-TOP TOM
Default Oil pressure warning
Is there any other warning of low oil pressure beside the gauge in the dash?
Old Apr 23, 2011 | 12:18 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
There is the DIC, But they both work off the same sensor.
Old Apr 23, 2011 | 09:29 AM
rws.1's Avatar
rws.1
... I'm guessing your oil pressure sensor is pegged and you are debating whether to change it....
Old Apr 23, 2011 | 10:14 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If its pegged out, then you've got a common failure of the sender and need a new one. If its zero, is there any clattering from the engine? If so, shut it off instantly.
To Oil pressure warning
