[Z06] flashing check engine light, Freaking out, please help!
Old Apr 23, 2011 | 09:31 PM
"ZOSICKS"'s Avatar
"ZOSICKS"
Default flashing check engine light, Freaking out, please help!
About 3 months ago I ordered a set of new MSD wires from west coast corvette, I changed the plugs to diamond fire while i was at it, had some trouble getting one of the plugs out and back in, but was fairly confident it went in fine after a fight.
The car doesnt get driven much but this has happened twice now...
First time;
Driving along, car starts to run crappy like its mis firing and then solid check engine light. One of the spark plug wires blew into bits, so thats explained, no biggy, easy fix.
Second time;
Driving, get on it in 2nd shift to third and a hickup @ 5k, let off(thinking to self, hmm weird)
Do the same again, hickup in second @ 5K and then hickup in 3rd @ 5k, then flashing check engine light and running like sh**.
Not sure what to do next, checked all the wires again...? thanks for any input guys.
Old Apr 23, 2011 | 09:41 PM
danziger's Avatar
danziger
Flashing usually indicates a mis-fire...replace the wires with stockers and see if that fixes it. You may have gotten a bad set of wires.
Old Apr 23, 2011 | 11:52 PM
"ZOSICKS"'s Avatar
"ZOSICKS"
Ya I did that the first time it happened and than this .... I'll have to check them again.
Old Apr 24, 2011 | 03:34 PM
DSM TJ's Avatar
DSM TJ
What number cylinder is the misfire on?
Old Apr 24, 2011 | 05:19 PM
Larry Myers's Avatar
Larry Myers
My 06 Zo6 developed a bad miss at high RPM. The Vette tech. called the GM Tech Center and thier response was did the car have aftemarket plugs. If so, replace with OEM plugs. That was not the problem as the car had OEM plugs. What it did have was a bad alternator.
Old Apr 24, 2011 | 07:59 PM
"ZOSICKS"'s Avatar
"ZOSICKS"
Really an alternator? Ok thank you I'll check that too
Old Apr 24, 2011 | 08:47 PM
"ZOSICKS"'s Avatar
"ZOSICKS"
You know I don't know
Old Apr 25, 2011 | 06:23 AM
4SFED Z's Avatar
4SFED Z
Whqt does the DIC say? Codes?
Old Apr 25, 2011 | 07:51 PM
"ZOSICKS"'s Avatar
"ZOSICKS"
It was a bad wire, thanks everyone. I feel silly
To flashing check engine light, Freaking out, please help!
