Gas Guage Problems...
Old Apr 23, 2011 | 11:02 PM
tuckin18s's Avatar
tuckin18s
Default Gas Guage Problems...
What would cause the gas guage to bottom out?? It works fine for a little bit them bottoms out?? You can shut the car off and then restart it and it works fine for about 50 miles them goes to Empty??? I havent a clue whats going on?? Can some one help me??
Old Apr 23, 2011 | 11:34 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Your fuel sender might be to blame. Try running some Techron or Seafoam cleaner in your tank during your next fill up. If that doesn't clear it up then your sender might need to be replaced.
Old Apr 23, 2011 | 11:35 PM
The fuel sending units in the C5 have a tendency to get sulfur deposits on them from the gas and that causes the units to misread. Try running a bottle or two of Techron through your gas tank and see if that clears up the problem. Many times it does. Then just put a bottle in every so often to keep it clean. Many top tier gas brands will have the additive added to them.
Old Apr 23, 2011 | 11:53 PM
Carcass's Avatar
Carcass
Something you might try (it worked on my '98)is to lay down and reach under your Vette just in front of the rear tire,and unplug/plug in the fuel sending unit connectors a few times(both sides)
Being mounted on the bottom rear of the tanks,the connectors are exposed to a lot of water and other road crud,which can seep into the connector and cause intermittent,or erratic operation of the fuel gauge.
Techron is also a good idea-I put a jug of it in the tank every 3 months or so-but my gauge was never 100% till I did the plug/unplug thing to the sending unit connections.
I did it about 6 months ago,and I haven't had a false reading since...
Ricks-LS1's Avatar
Ricks-LS1
I had the same problem with my car. I put 20 oz. of techron into about a half full gas tank. I let the car sit for a couple days. I haven't had a problem since then.
Old Apr 24, 2011 | 12:33 AM
YellowPowerC5's Avatar
YellowPowerC5
Try some techron... it's on sale right now at Advance
Buy one 12oz get one 12oz free
http://shop.advanceautoparts.com/web...CGRP2030C_____
Old Apr 24, 2011 | 02:18 AM
cannonguy's Avatar
cannonguy
Default Now there's news you can use!
Stuff is not cheap, so a 2 for 1 is a great excuse to hit the parts store.
Mine stuck for the first time ever the first week I resumed driving this spring. Techron in a tank of premium cleared it right up.
Old Apr 24, 2011 | 07:09 AM
slvr bulit's Avatar
slvr bulit
I did this last year year and it worked for me as well.
Old Apr 24, 2011 | 07:41 AM
vette.mix's Avatar
vette.mix
I going to have to try that, been doing the techron but it has not fixed the fuel guage
Old Apr 24, 2011 | 11:10 AM
jrose7004's Avatar
jrose7004
That's a well documented C5 problem. Run some Techron through there fairly often and don't use ethanol.
Old Apr 24, 2011 | 11:22 AM
ricknyc23's Avatar
ricknyc23
here we go again....
To Gas Guage Problems...
