does anyone here have the projector lights that are found on the auction site? i'm wondering how the quality is and how well they fit in the car. is there any problems with bouncing or vibrating when going down the road or hitting a bump? All input would be appreciated.
the ones i see on ebay are modified concept and D5 concepts. im assuming they will be the same as the ACA lights? i thought the ACA lights were the expensive ones.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
ACA sold the company years ago. The lights are stampped ACA on the front.
Modified concepts is the seller but when you get them they have ACA molded right in to the lens. I just got some about a month ago and they were very good quality and fit great.
Does the wiring harness that comes with the "auction" headlamps keep high and low beams on at the same time? Or is it essentially the same thing as JW harness?
If your going to use HIDs in these spend the extra $10-25 and buy a battery based relay harness to insure proper voltage and amperage.
Tons available on eBay
