DIC error codes & messages (fixed)..TY CF
Old Apr 25, 2011 | 08:56 AM
TwoSmoke's Avatar
TwoSmoke
Default DIC error codes & messages (fixed)..TY CF
It finally happened. I had my first malfunction. And the great info here at Corvette Forum helped me fix it. Thanks a million...saved me from hanging myself!
The story:
I ignored the warning she was trying to send me. One day the fuel gauge went to empty and I know the tanks weren't empty. And the check traction control message came up. I just pulled over and shut the car off and when I restarted it.....all was fine. So I forgot about it.
A week or so later I was in my little town running errands and then planned on riding to the big city to get other stuff (love finding excuse to drive Vette!). When I came out of store and started Vette I got all sorts of error messages and my windows as well as all driver door controls quit. A/C quit. Radio quit.
Panic mode was setting in.
I read CF all the time and remembered all the crazy stuff that happens when batt voltage gets low. So I went to Autozone and was going to buy battery. Employee is a Vette owner and said I should just clear codes and all would be fine. Hummmmm,,,seems strange that just clearing codes would work. Something had to make the PCM flip out like that I thought.
Not knowing how to clear codes, the guy comes out and shows me how. It works, all systems go.
But by the time he gets out of car and I get in, all systems fail again. Being optimistic and looking for quick fix I bought battery. Been wanting one anyway because I didn't know how old this battery was since it was in car when I bought it. But no luck. All error messages and failures remain.
The car ran fine. So I drove home whimpering, crying and pitching hissey fit because Vette was broke and doomsday scenario about dealership labor charges and new PCM cost was setting in.
So I pulled in garage and since my life was now over as I knew it I planned on hanging myself from rafters. But at the last minute I figured I should at least try and fix it.
I knew this had to be covered at some point here at CF so I did massive searches. I started with the grounds. The one by the battery looked good after removal. I disassembled the muti-ground wire modules on frame behind each headlight. Looked good. Started car and still had same problem. I can't believe how many ground points on this car.
I stopped after checking three and thought I would move on to something else. I sat in car thinking. Painful, but I did it anyway. I reached over and hit passenger side controls and they worked! Hummm, just driver door controls don't work. So I went in that direction. More MASSIVE searches on CF forum. Finally I hit this one that mentioned the wiring harness from the door to the car sometimes chafes.
I run out to car and pull out the accordion tube and the wiring harness and connectors. Start the car and.......PRESTO......everything works.
Sure enough I have bare wire just like the CF thread shows. I taped it up and reinstalled. Went for a 140 mile drive and my life is back to normal.
Thank you, thank you, THANK YOU Corvette Forum and all the great members that contribute information here.
You guys
Here is link to thread that helped me. Post 640 has pic of chaffed wiring harness.
http://forums.corvetteforum.com/c5-t...n-long-32.html
Old Nov 18, 2011 | 09:24 AM
joemojica's Avatar
joemojica
3rd Gear
I have a 2000 coupe. Mine is doing the same thing, except that the panel works when I open the door and fails when I close it. All guages except the voltage meter, go haywire and all messages from A to Z start popping up. I had replaced the battery just 2 weeks prior with no issues. I will check the harness and if anyone has additional info before I have to get an expensive expert to take a look at it, this would be greatly appreciated.
Old Nov 18, 2011 | 09:37 AM
TwoSmoke's Avatar
TwoSmoke
WOW....talk about a thread back from the dead. Seems like this happened much longer ago then April of this year.
I have not had anymore problems since I fixed the driver door harness inside the accordian tube.
If I remember correctly, the problem is actually a loose pin inside the connector. Not chaffing like originally thought. Evidently when I pulled the harness out from inside the door and wrapped the connector with tape, that caused the loose pin to make contact again.
It has been working fine so I never pulled it back out and looked for a loose pin.
I sure hope this fixes your problem.
Good luck.
To DIC error codes & messages (fixed)..TY CF
