[Z06] Surging after install
Old Apr 25, 2011 | 10:17 AM
chase33's Avatar
chase33
Cruising
Default Surging after install
I just got a Vararam CIA with power duct, lg street long tubes, and B&B bullet exhaust itstalled on my 03 Z06. Sounds awesome but runs like crap my check engine is on I know the sensors have to adjust, but how long should it take. Info anyone.
Old Apr 25, 2011 | 11:10 AM
Never Late's Avatar
Never Late
powerducts can cause turbulance issues due to MAF relocation which can lead to the crappy performance and check engine light, also the longtubes if you are running a catless midpipe can also throw the engine code, did you have a tune done? I am very sure if you get a tune it will correct everything and your car will run great.
Old Apr 25, 2011 | 12:44 PM
Paul 75 L82's Avatar
Paul 75 L82
A tune is always the best answer, but a good 30 mile drive over 55mph might help somewhat.
Old Apr 25, 2011 | 12:45 PM
chase33's Avatar
chase33
Cruising
No tune done, long tube with hf cats. will this work itself out or just get a tune?
Old Apr 25, 2011 | 01:56 PM
Dennis Wilson's Avatar
Dennis Wilson
Best get a tune.
Old Apr 25, 2011 | 10:03 PM
just inc's Avatar
just inc
Make sure you didn't criss cross the front 02 sensors
Old Apr 25, 2011 | 10:38 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
With the VARARAM alone, there are ways to get the car to adjust with that alone. With LTs and HF cats, the best way to MAX out the power those will provide is a tune. Once you get it tuned out, the car will be a much more powerful ride!
Old Apr 25, 2011 | 10:39 PM
bethunsl's Avatar
bethunsl
I have the vararam and a powerduct on my Z. I had codes too. What I ended up doing is calling Haltech and getting the honeycomb. It installs after the CIA and right in front of the mass air flow sensor. It smoothes out the turbulent air from the CIA. Disconnect the negative post on the battery install the honeycomb connect the battery back up. Start the car and let it idle for a few minutes and then drive the car normally at first so the computor could learn the changes. clear the codes before the install of course and you should be in business. My car was giving left and right bank lean conditions before the install. I haven't seen it since. ( about 2k miles ) The part is about 50 bucks and is pretty easy to install. Don't do like I did and go to the dealer first. I got robbed and they didn't fix the problem.
Old Apr 27, 2011 | 10:31 PM
jdbush23's Avatar
jdbush23
I put the same set up on my car and had surging as well after a tune. Tuner told me the rt o2 sensor was bad so i replaced it and same thing. Got the Halltech honeycomb and 95 percent of the surge is gone but still have it alittle but its driveable now and really is not noticeable, before the honeycomb i didnt even want to drive it was so bad. My best advise is get the honeycomb for 50 before the tune and see how that works.
Old Apr 28, 2011 | 05:25 PM
PR1AWRet's Avatar
PR1AWRet
I would give a call/pm to one of the tune guys and see if they can hook you up with a mail order tune first. ECS or RPM.
I have a very well sealed Vararam CAI, Power Duct, and the Haltech honeycomb and still get the lean codes but I'm going to send my ECM in for the tune. I still have a small amount of surging but is 90% better than what it was without the Power Duct.
Old May 1, 2011 | 03:27 PM
sprayed1998's Avatar
sprayed1998
Your fuel trims are off with the new intake setup. You need a tune.
Old May 1, 2011 | 07:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We can take care of that with our mail order tune special.
Old May 4, 2011 | 08:12 PM
Quickshift_C5's Avatar
Quickshift_C5
I'm so confused with this surging stuff.
Halltech says their honeycomb insert will fix it.
Tons of members here say the honeycomb insert fixed theirs.
People in this thread say the car needs a tune?
...so which is it? I installed a Halltech Venom 2 intake that relocated the MAF and am having slight surging. Appears to run ok up top, best I can tell, but it does seem to be surging.
My car has the OEM 1/16" design honeycomb insert in the MAF. I'm considering getting the Halltech one, but not convinced it will fix the issues. I don't know what to do or who to believe.
To Surging after install
