Where To Put Ipod
Old Apr 26, 2011 | 01:59 AM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default Where To Put Ipod
I ordered the PAL set up(nav) and am wondering if I should put the IPod in the console or rear storage compartment. I am not familiar with iPods so could you tell me if I have to physically turn the iPod on or does it turn on when I select the proper XM mode? Thanks a lot. Mike
Old Apr 26, 2011 | 07:59 AM
VET IT B's Avatar
VET IT B
I chose the center. It's easy access and fits nice. I added a insulated tunnel plate and have no problem with heat.
Old Apr 26, 2011 | 08:03 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
FYI
the PAL setup is for a C6
Old Apr 26, 2011 | 08:41 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I leave mine connected in the glove box. Mine comes on with my kenwood stereo
Old Apr 26, 2011 | 09:08 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I'm also considering a Kenwood head unit and the stereo installer I spoke with also suggested the glovebox because the Kenwood touch screen duplicates the controls.
Does your headunit also power up the IPOD, meaning it's not running on battery power when playing? Pretty cool if you can leave it in the glovebox and it automatically turns on/off.
Another advantage of the Kenwood head unit is that since I drive a vert, the power antenna only goes up if I listen to the radio. If listening to the IPOD or CDs, the antenna stays down.
To the OP, if you consider upgrading to an IPhone, you may want to wire it through the center console.
Old Apr 26, 2011 | 10:51 AM
Kale's Avatar
Kale
The heat in the center console would concern me for most cars, especially in the summer. I ran my ipod cable into my glove box.
Old Apr 26, 2011 | 11:00 AM
Rob04C5LM's Avatar
Rob04C5LM
My connector comes out through the ash tray because I have to change tracks, etc. through the iPod itself. It is super easy to route the cabling that way and the door conceals the cable when parked. When I upgrade the head-unit from factory to aftermarket and don't have to change tracks from the iPod, I'll probably keep it in the glove box to avoid the heat.
Old Apr 26, 2011 | 01:18 PM
B-STOCK's Avatar
B-STOCK
Originally Posted by c5 BearsFan
FYI
Besides the 2000 Vert I have a 09 Coupe. I have been so active in the C5 Forum I posted here by habit.
Now that I see some of the nice C5 setups it gets me thinking.
Old Apr 26, 2011 | 01:31 PM
B-STOCK's Avatar
B-STOCK
I installed the Anetnna Bypass because I usually listen to CDs and rarely listen to the radio. Also I don't have to remember to turn off the music when I put my care under the lift.
Old Apr 26, 2011 | 01:37 PM
Daddyrama31's Avatar
Daddyrama31
That sounds like a cool option. I never listen to the radio either. How did you do the bypass? Do you need a special part?
Old Apr 26, 2011 | 02:08 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
mine is in the center console no problems
Old Jul 18, 2011 | 11:43 PM
1quick1's Avatar
1quick1
My iPhone4 gets extremely warm and has overheated (it displays a too hot message and stops playing until cooled) while keeping it in the center console. Hence why I've been checking out these threads. Just a warning to other iPhone owners. From my experience it doesn't happen often but the phone pretty much always gets extremely hot.
Old Jul 19, 2011 | 12:06 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Same here, I have a Pioneer, At first I put it in the center console But the heat was too much then moved it to the glove box, . I can control it with my Pioneer 920.
Patches's Avatar
Patches
I triple-insulated the wife's cabin and have no heat issues in there. Here's where I placed her iPod. It's integrated to the Kenwood system I installed.
http://forums.corvetteforum.com/audi...-overhaul.html
Old Jul 19, 2011 | 03:22 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
That's the way we have it and no issues at all. We never touch it as mentioned since the Kenwood deck controls it.
To Where To Put Ipod
