Question Front wheel size
Old Apr 26, 2011 | 03:52 PM
02*C5's Avatar
02*C5
Default Question Front wheel size
Can i put a 18X10.5 wide wheel in the front of the Vette? I've done 9.5 but this is a full inch wider and I am torn between a 285/30/18 or a 295-30/18 for the front.
Old Apr 26, 2011 | 05:31 PM
NealB's Avatar
NealB
the OEM Z06 rears will go on the front and with a 295 tire
I know a company that has 8 cars with this arrangement
no spacers either
but, be aware that your TCS won't like having the front and rear tires the same size
the OEM ratio of diameter F to R is 0.97
so run larger/taller rear tires or turn off the TCS each time you drive
otherwise, any time you get any angle/drift into the car the electronics will take away throttle and/or apply rear brakes just when you don't want that to happen
Old Apr 26, 2011 | 06:18 PM
02*C5's Avatar
02*C5
no spacers either
Great thanks. I am going with either a 335/30-18/345/30-18 in the back. I am about to receive a set of speedlines I had extended to 18X12 so I think that the ratio diameter I have covered, I just needed to make sure. I was going to move the rears to the front, take the fronts and have them reduce to an 18X4 to run it as a skinny at the track.
Thank you very much.
Old Apr 26, 2011 | 07:23 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
A 30 series tire, Hold on for dear life. Thats a ruff riding tire.
Old Apr 26, 2011 | 11:40 PM
02*C5's Avatar
02*C5
yes I know running one right now 315/30 arghhh
Old Apr 27, 2011 | 12:04 AM
02*C5's Avatar
02*C5
Originally Posted by 8VETTE7
Bill, I have 345/30-19's mounted on 13" wide CCW's on the back of my 04 vert and I find that it rides better than the 275/40-18 (non runflat Mich pilot sport PS2) that I had on the back until I got my new CCW wheels.
depends cause where i live the roads tend to be shitty.
To Question Front wheel size
