Head Light Drama
Old Apr 26, 2011 | 07:34 PM
Loverofcorvettes's Avatar
Loverofcorvettes
Default Head Light Drama
Can anyone help. If have a 2002 and the drivers head light goes up, and down all the way great just like it should. However when the light goes all the way down for some reason it comes back up about two inches and does not close after that. Any ideas on a possible solution??
Old Apr 26, 2011 | 08:31 PM
Here is a technical service bulletin that was issued for the 2000 C5 - may or may not be your problem:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
Another post on the forum mentioned checking to make sure the battery was completely charged.
Worth looking into and perhaps someone else may have other ideas.
Old Apr 27, 2011 | 11:22 AM
Loverofcorvettes
Thanks for the info, I will give it a try. The parts can't cost that much so its worth a shot. Thanks again.
To Head Light Drama
