1999 Corvette High Beams won't work.
Old Apr 27, 2011 | 01:26 PM
vdrayton's Avatar
vdrayton
1st Gear
Default 1999 Corvette High Beams won't work.
I have a 1999 corvette and the high beams will not work, low beams are fine. Is this a head light switch problem? Does anyone have a diagram of the head light circuit?
Thanks,
Vern
Old Apr 27, 2011 | 02:54 PM
melvingregory's Avatar
melvingregory
Be sure and check your fuses under the hood. You have fuses for the low and high beam lights. If not that probably your column switch.
