HELP!! seat repair problems
Old Apr 30, 2011 | 04:55 PM
tncop2361's Avatar
tncop2361
Default HELP!! seat repair problems
Driver's power seat froze up yesterday...it has had the rocking problem since I bought it last year. I thought the problem would be a simple repair, but it is much more. After getting the seat out I found that the metal piece that attached to the rear cross piece that i THINK moves the rear up/down is broken (see pic 1) and then I found that the flex shaft from the motor in the front is broke (see pic2).
Any ideas I am just putting it back together with the seat close to where I like it and leaving the connections unplugged.
The piece circled is broken along the dotted yellow line
Old Apr 30, 2011 | 07:26 PM
killain's Avatar
killain
Oldtimer
Default Seating arrangement ?
Considering your problem, I'd call Contemporary Corvette @ 215-788-8693 and they will send you a used seat and you can finish your repair job & www.worldofcorvettes@aol.com The web address doesn't work. Just call them Monday morning. They ship UPS every day. Good luck !
