No brake lights!!!
Old May 2, 2011 | 10:25 AM
eddievetter1's Avatar
eddievetter1
7th Gear
Default No brake lights!!!
Hi guys and girls... Long time reader, first time poster...
My 99 convert has no brake lights. Center brake light works, but the main brake lights do not. (?)
any ideas?
Thanks.......
Old May 2, 2011 | 04:42 PM
GHL4505's Avatar
GHL4505
Hmmm! I had that same problem once.
I have LED tail lights and a bypass harness. The flasher bypass harness went bad. Replaced the harness and it has worked fine ever since. Not sure if that is what you have going on.
Old May 2, 2011 | 04:49 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Did your car ever have Euro tail lights? That mod required that the white brake light wire be cut underneath the dash in order for the rear harness to work. If they were ever reverse engineered back to stock, the white wire would have needed to be reconnected. If so, it may have come lose. Just an idea...
Fuse maybe?
Old May 2, 2011 | 04:55 PM
rpm462's Avatar
rpm462
Just went through the same thing and had to replace my hazard flasher module to left of center AC duct.
Old May 2, 2011 | 04:56 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Fuse and hazard switch are the usual causes.
Old May 2, 2011 | 11:04 PM
eddievetter1
7th Gear
Never had Euro lights. Bone stock. I ordered this car new.
I ordered the hazard switch today.
On the exploded view from the GM dealer, it is the hazard switch directly under the button.
Is this what I need?
Through reading, it was kinda confusing... some talk about a knee bolster, flasher unit, etc., etc., etc.......
Some called it the "flasher unit".
The woman at the GM dealer counter said she didn't know what that was and when typed in their computer, it didn't spit out anything called a "flasher unit"
I will await all replies....
It's getting warm and I can't drive my ride!!! :-(
I need advise on a cam too....... LOL
Livernois told me not to get anything on a 112 as it would "surge"..... (?)
114 is too close to stock..... I want it to SOUND like I put a cam in it if I'm going to spend the money...... let alone the performance......
More on that later.....
Thanks for the help guys.......
Old May 2, 2011 | 11:20 PM
Bill Vett's Avatar
Bill Vett
Try pushing the flasher button on and off 15 /20 times and see if it works. Could be a dirty contact.
Old May 20, 2011 | 08:42 AM
eddievetter1
7th Gear
Default I have brake lights again!!! :-)
Hey guys/girls, the hazard switch replacement fixed my "no brake lights" issue......
Who woulda thunk?........
I appreciate the help I got here......
It was TIGHT to try to get that switch in there.... wow....
I fished a string through the hole, and used a vaccuum to suck it through the radio hole. Tied it to the switch and the string helped me guide it into the hole in the dash....
Again... thanks for the help.....
any ideas?
To No brake lights!!!
