Corsa Touring or Sport for Daily Driver?
I recently installed the Corsa Touring System with the Corsa X-Pipe. Unfortunately, I am unhappy with the results. Though they are bolder than stock, I guess I was really expecting something more aggressive.
I’m thinking of swapping them out for the Sport version, but two things make me wonder if that’s a good idea:
1. My ’04 is my daily driver and after (if?) the novelty wears off, will I grow weary of the more aggressive sound?
2. I live in a quiet bedroom community. While leaving the community during weekday mornings, sometimes I’ve got to get enthusiastic to squeeze between two cars. (OK, I get enthusiastic on the weekends, too.) Is my homeowners’ association going to ask me to lay off the noise?
I guess what I’m asking is: shall I go for the Sports, or stick with the Touring?
Do YOU have Corsa Sports on your Daily Driver?
s’noJob
06/02/2011 - UPDATE: I went with the Sport edition and have been very pleased with them. They're quiet when I need them quiet, and loud - well, the rest of the time.
s’noJob
I have the Corsa Sport (formerly known as Pace Car) on both of my C5's. My Pace Car has just the system and an X-pipe. My black car has long tube headers as well.....neither is what I would call loud, especially in town at low speed.
They get loud at WOT, but never what I would call too loud.
If you don't accelerate using more than something like 15-20% throttle in the neighborhood and shift into a higher gear, you should not have issues. Just drive easy. "spirited" driving in the neighborhood just causes problems.
I have LT's and the pace car system (on a blown 346) and even starting my car up it's loud as hell! I almost failed a tracks noise restrictions at idle (and that's supposed to be 1500rpm under redline). I'm happy with my set up because it's my weekend toy, if I was starting the car up every morning I'm sure my neigbours would get pretty ticked off in a hurry.
Go for the best of both worlds and install a set of cut outs.
I don't run headers but I have the X-pipe with Corsa Xtremes. I love them. They are only loud when you get heavy into the throttle and in normal driving will not disturb those around you (I live in a quiet community). In the lower rpm range they are fine and have zero drone while cruising at highway speeds.
Received 19,305 Likes
'20-'21-'22-'23-'24
I have Corsa Indys on my car - they sound great, but when you go WOT, you can hear them for quite a distance. However, they don't seem to make the Indy system any more - but I would guess the Pace Car is similar. Anyway, no drone or popping with this system.
As far as the HOA goes, that will depend totally on how picky they are on noise levels.
2021 C6 of the Year Winner - Unmodified
The "sport" or "pace car" system would be just fine for a DD. Not that much louder than stock unless you put your foot into a lot and even then it not that obnoxious inside the car.
Received 1,675 Likes
Corsa Pace Car system would do what you want.
St. Jude Donor '10
I recently had the Corsa pace/sport exhaust put on w/x pipe no headers. It's a little louder then stock at idle a normal driving. At WOT it's got a nice tone to it and louder then stock. I would have gone with the extreme or Borla because I like it loud but my wife drives the car every now and then and she didn't want it that loud.
She approves the sound of the Corsa pace/sport exhaust system. If that helps.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Corsa "pace car" exhaust ?
s’noJob
s’noJob
Received 2,681 Likes
2018 C5 of Year Finalist
Years later, I am still very happy with the system. It has a nice low key rumble that should not be a problem cruising through your neighborhood, however when you do hit it, you know it!
St. Jude Donor '13
Corsa Indy Pace Car/Pro Tip with Corsa X-pipe. Neighbor friendly at low rpm's and sounds great above 3500 rpm's.
Very happy after 8 years of use......
decision
As the OP, I'd like to update this post. The question was, should I switch to the Corsa Sport or keep my new Corsa Touring?
Well, tonight I had the good fortune of having the opportunity to experience the Sport edition. A member of my Corvette club, Corvettes International, had just installed a Sport on his C6.
The ride-along made my decision a lot easier.
I'm going to switch to the Sport.
s'noJob
s'noJob
s'noJob
s'noJob
