Need instructions for installing GMPP Red Spark Plug Wires
Can anyone tell me which wires go to which cyclinder?
Thank you!
The instruction sheet that came with the spark plugs has a length on there for each cylinder, but I want to read the instruction sheet before I just start doing it. The sheet also has 4 separate sets of instructions for different size engines, but I can't read it.
I was hoping that someone who bought the same set still had their instructions and could post what it says for a non-z06.
So it has 4 sections:
1. Small block v8 135degrees, then the length for each wire.
2. Big block v8 135degrees, then the length for each wire, which are different than the small block.
3. Small block v8 90degrees then, the length for each wire, which are different than both 1 and 2.
4. V-6, which is obviously not my car.
So, this is what it says for #1:
Cyl 1 - 27.0" Cyl 2 - 32.5"
Cyl 3 - 28.5" Cyl 4 - 24.5"
Cyl 5 - 24.5" Cyl 6 - 23.0"
Cyl 7 - 23.0" Cyl 8 - 22.0"
There is no way this is measured in inches. In millimeters, the longest plug is 22mm.
This is why I need the english instructions because even though they are numbers, I still need to know the unit of measure for the numbers.
Cyl 8 = Shortest
Cyl 6 = 2nd Shortest
Cyl 7 = 3rd Shortest
Cyl 4 = 4th Shortest
Cyl 5 = 5th Shortest
Cyl 1 = 6th Shortest
Cyl 3 = 7th Shortest
Cyl 2 = Longest
So no one has the instruction sheet that came with the spark plugs.
Cyl 8 = Shortest
Cyl 2 = Longest
come to think of it, when i did my wires i pulled them out of the box and stuck them on with no fitment issues. didn't even see an instruction sheet.
Cyl 8 = Shortest
Cyl 2 = Longest
Also, this is assuming that I am using the 1st section.
The numbers for the 2nd section are:
Cyl 1 - 29.5" Cyl 2 - 33.0"
Cyl 3 - 30.0" Cyl 4 - 27.0"
Cyl 5 - 25.0" Cyl 6 - 24.0"
Cyl 7 - 23.5" Cyl 8 - 22.5"
The numbers for the 3rd section are:
Cyl 1 - 39.0" Cyl 2 - 41.5"
Cyl 3 - 37.0" Cyl 4 - 35.5"
Cyl 5 - 32.0" Cyl 6 - 31.5"
Cyl 7 - 30.0" Cyl 8 - 29.0"
I may just have to wait until tomorrow and call GM Parts House for the english instructions.
i don't get those instructions. they have your longest wire growing from 32.5 to 33 to 41.5, depending on which engine you put them on? i've heard of magic beans, but magic spark plug wires?
are you absolutely sure you got the right set of wires?
