Bridgestone RE760s
Old May 3, 2011 | 08:58 PM
B.Prug87's Avatar
B.Prug87
Default Bridgestone RE760s
Can these tires be rotated side to side?
Bridgestone tires
Old May 3, 2011 | 09:55 PM
C5 Corvette C5's Avatar
C5 Corvette C5
No they are not because they are a directional tire. With a asymmetrical tread pattern for improved handling and corning.
Old May 3, 2011 | 10:08 PM
B.Prug87's Avatar
B.Prug87
see thats where im confused because the 2 sides of the tires have different tread.there not gonna send you 2 of each with opposite tread patterns?1 side is going to be the outside edge. So if you rotate the tire from side to side your doing just that. Keeping the correct tread on the outside edge.
Old May 3, 2011 | 10:28 PM
onebighitter's Avatar
onebighitter
I just put a set on my car and they can be rotated from side to side. They are not directional but one side of the tire is the outside and has to be mounted on the rim correctly
To Bridgestone RE760s
