AC problems
Old May 4, 2011 | 09:36 PM
chevyguy04's Avatar
chevyguy04
4th Gear
Default AC problems
2003 Vette
When I try to turn the AC on the light turns on for couple seconds then blinks and turns off?
Can anyone direct me where I can find some answers?
Thanks!!
Old May 4, 2011 | 10:05 PM
dmarkshark's Avatar
dmarkshark
Thats usually a sign of low freon. Check it or have it checked.
Old May 5, 2011 | 07:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. A professional shop is the best place to go and shouldn't cost that much
Old May 5, 2011 | 10:45 PM
chevyguy04's Avatar
chevyguy04
4th Gear
Had the compressor replaced last spring....looks like she's going back to them.
I've heard that it will not come on if the outside temp is below 60 or 65...is this true??
Thanks for the replies!
Old May 5, 2011 | 11:16 PM
dmarkshark's Avatar
dmarkshark
No , not true. It is lower than that, but it also depends on the outside temp and what you have it set to. It will come on in the winter to take the moisture out of the air, just like most new cars do.
Old May 6, 2011 | 07:07 AM
dgrant3830's Avatar
dgrant3830
Its between 38-42 or somewhere in there that the system will not turn on the compressor.
To AC problems
