Suggestions for End Links?
Old May 5, 2011 | 11:49 AM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Default Suggestions for End Links?
Thanks to the posts here and in C6 General, I've finally figured out the source of the clunks in my C5 (after eliminating the rear axle nuts as an issue). I reached under the car and found the right front link pretty stiff, but the LF, LR and RR links can easily be twisted about -- loose enough to suggest the socket joints are toast.
What I haven't sorted out is: which links to get to replace the OE end links. I understand there is now a GM HD end link (same as on the C6?), as well as aftermarket (e.g., LG's end links).
Reasons to prefer any one source over the other? The C5 is a daily driver that sees the *occassional* track day, so there's not really a need for track-oriented suspension pieces on this car.
Thanks for any recommendations!
Old May 5, 2011 | 11:50 AM
imavettegirl's Avatar
imavettegirl
c5 aluminum links.
use a sponsor.
Old May 5, 2011 | 11:54 AM
mneblett's Avatar
mneblett
Originally Posted by imavettegirl
c5 aluminum links.
use a sponsor.
Thanks -- I should have mentioned, the car is an '04, with Al links.
I'm trying to figure out whether to do these again, or go with something better?
Old May 5, 2011 | 01:18 PM
PhilsFRC's Avatar
PhilsFRC
Default Links and Nuts
The most updated OEM design is universal for ALL C5s and C6s including the ZR1. Link p/n 20822934, locking nut p/n 11515744.
Old May 5, 2011 | 02:49 PM
mneblett's Avatar
mneblett
Thanks!
To Suggestions for End Links?
