Fog lights question??
Old May 6, 2011 | 07:53 AM
Button's Avatar
Button
Default Fog lights question??
When I turn on my fog light the interior dash lights come on but the lights don't?
Any way to fix / check this??
Old May 6, 2011 | 12:58 PM
MrGary2011's Avatar
MrGary2011
Sounds like the wireing behind the fog-panel lights panel is crossed. Take out the panel and check. If looks normal disconnect one and see if the problem is still present. What happens when you turn on your parking lights?
Old May 6, 2011 | 01:11 PM
Kevin Kuse's Avatar
Kevin Kuse
Do you have HIDs or Stock Bulbs? Mine has been a little quirky since I change to HIDS.
I figure I will need to add the HIDs inline resister.
http://shop.jwmotoring.com/product.s...8&categoryId=4
Check your grounds, on frame rail between RH headlamp assembly & RH wheelhouse. SP110 @ G102 are attached there.
Old May 6, 2011 | 02:08 PM
MrGary2011's Avatar
MrGary2011
My HID fog lights were plug and play, no resistor. I am right now installing JWs HIDs for the low beam and and from the readings bought the inline resistor for them whic is supposed to eliminate issue with headlights not retracting on low beam. I do kown that very strange things begin to happen when the battery is not fully charged. Make sure your batt is fullly charged.
To Fog lights question??
