Help installing TMPS.
Old May 8, 2011 | 02:06 PM
Jims2001's Avatar
Jims2001
Default Help installing TMPS.
I have new monitors for my new repros wheels and they don't want to fit. Can't get the threads started on the nut. Am I missing something? It's like the indent where the rubber washer sets is too thick or something. I can't get one started but on the others I just can't get the threads to catch. The monitors were suppose to be a GM part number. HELP!
Old May 8, 2011 | 03:19 PM
jrose7004's Avatar
jrose7004
If push comes to shove, you can always install them with bands.
Old May 8, 2011 | 08:37 PM
Jims2001's Avatar
Jims2001
I just need to know what to send back, wheel or sensors.
Old May 8, 2011 | 08:44 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
In some cases the wheels are not TPMS friendly, When I bought my wheels I had to ask to make sure the TPMS will fit the wheels, Most Repo wheels are TPMS friendly, What wheels are you using?
Old May 8, 2011 | 08:58 PM
Jim - check with the vendor you bought the wheels from and make sure they were designed to accept the stock TPS. You might also want to verify that the TPS are actual GM products - should be a part number on them that you can check by going to the gmpartshouse.com web site and matching up the numbers. If all else fails, here might be an option:
http://www.tpms.ca/VALVES.html
Have not tried those adapters - just saying it might be an option. Obviously you would need to research and see if they are any good.
Old May 8, 2011 | 09:12 PM
Jims2001's Avatar
Jims2001
C6 Chrome, Front wheels came from Corvette Wheels and the rears came from JW Motoring. They both came from China.
Old May 8, 2011 | 09:18 PM
Mr.Bill's Avatar
Mr.Bill
I had C6 5 spoke chrome and they were sold by OE Performance and my sensors worked with out issue, I would think the ones that JW sold you should take the sensors.
Does your sensor look like this.
Old May 8, 2011 | 09:27 PM
Jims2001's Avatar
Jims2001
That what they look like.
Old May 8, 2011 | 09:30 PM
Mr.Bill's Avatar
Mr.Bill
Make sure the rubber seat is going into the wheel hole all the way.
Old May 8, 2011 | 09:33 PM
Jims2001's Avatar
Jims2001
It's in all the way. Really seems the area is too thick.
Old May 9, 2011 | 09:57 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I replied to your email before I saw this thread.
Yes the wheels we sold you work with all C5 TPMS.
I would try a shop that deals with TPMS. They should be able to assist you with these.
Old May 9, 2011 | 05:31 PM
Jims2001's Avatar
Jims2001
Thanks Johnathan, I do have the right sensors don't I? Can I be doing something wrong? I stick it through the hole and try to screw on the nut. What else is there?
Uploaded with ImageShack.us
Old May 10, 2011 | 07:59 AM
JW Motorsports
Banned Scam/Spammer
Yep looks right. How easily does that black plastic compress? Maybe some firm pressure on it will help. The grooves inside the wheels are def. made for it. Hopefully they didn't change the sensors up a bit on us.
Old May 10, 2011 | 06:51 PM
Jims2001's Avatar
Jims2001
I will try again with a valve stem tool to pull on the valve stem while screwing on the nut.
Old May 11, 2011 | 04:33 PM
ljthe2nd's Avatar
ljthe2nd
You're not trying to put the nut on up side down are you?
Old May 11, 2011 | 04:51 PM
Mr.Bill's Avatar
Mr.Bill
good point
Old May 11, 2011 | 08:55 PM
Jims2001's Avatar
Jims2001
I can't imagine someone would even try that.
To Help installing TMPS.
Old May 29, 2011 | 12:04 PM
JW Motorsports
Banned Scam/Spammer
I just wanted to update this in case anyone searches and finds this thread.
It turns out he was sent the wrong nuts for the TPMS. He reports everything is good to go now
Old May 29, 2011 | 12:23 PM
Jims2001's Avatar
Jims2001
Thanks for your help Johnathan, new wheels are excellent.
Old May 29, 2011 | 05:00 PM
JW Motorsports
Banned Scam/Spammer
appreciate the business
