02 50th ann...??
Old May 9, 2011 | 03:01 PM
Downtimela's Avatar
Downtimela
Default 02 50th ann...??
My car is titled a 2002, but has the 50th symbol in the gauge cluster. I thought only the 2003's came in this trim level.
is this common???
Old May 9, 2011 | 03:04 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
Possibly an '02 with a replacement cluster or it's titled incorrectly.
What's your vin #?
Nick
Old May 9, 2011 | 03:28 PM
jrose7004's Avatar
jrose7004
If it's an 02 it's not a 50th.
Old May 9, 2011 | 04:06 PM
I agree that most likely the cluster has been replaced with one from an '03.
Old May 9, 2011 | 04:40 PM
Cybermind's Avatar
Cybermind
is this common???
If the 50th symbol is only on the gauge cluster and no where else, then you can be sure that the cluster was replaced with a used one from an '03. On 03's, the symbol is on the front and rear emblems also and there were no 02's with it.
Old May 9, 2011 | 06:26 PM
SCM_Crash's Avatar
SCM_Crash
IT'S SUPER RARE!!! SELL IT FOR A BILLION DOLLARS! 1 of 1 50th Ann. 2002 Corvette!!!!
J/K...
It's likely just a replaced gauge cluster. As long as the mileage is right on everything and there's no ODO/records differences, you're good to go.
Old May 9, 2011 | 09:35 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
is this common???
If your car is an o2 someone changed the dash, If this is the case you have another issue, Mileage, If someone changed the dash you have no clue what the miles are on yout car, Also if it is a 50th I believe the front emblem will say 50th also.
Old May 9, 2011 | 09:55 PM
Cosmic Charlie's Avatar
Cosmic Charlie
Here in Massachusetts if the dealer changes the Cluster, he is required to put a sticker on the driver's door jamb saying so. (I think) even if the correct mileage is on the new cluster ... (most usually when the car is somewhat new)
but then again - it's simple to change the cluster by most anyone - either to get a new cluster or get new mileage ... or both
new cars (not 2002 ...) are now different, mileage is stored in the main computer (?) and not the cluster
did you try car fax or even a GM dealer's general records ?
or just be happy ...
Old May 10, 2011 | 12:53 AM
manley845's Avatar
manley845
Originally Posted by Cosmic Charlie
new cars are now different, mileage is stored in the main computer (?) and not the cluster
The mileage will follow the cluster. I bought a spare cluster that I was going to modify and then install in my car; the mileage did not remain the same when I installed the spare cluster, it indicated the mileage of the spare cluster.
Old May 10, 2011 | 09:06 AM
Downtimela's Avatar
Downtimela
oh lawd here we go
thanks for the help all, any other way to check mileage?
Old May 10, 2011 | 09:20 AM
Downtimela's Avatar
Downtimela
Carfax shows no issues reported, just general inspections/maintenance.
The mileages reported seem to look normal all the way up to the highest recorded which is where it is now around 50K
not sure what else i could check????
Old May 10, 2011 | 09:24 AM
zeeohh6ex's Avatar
zeeohh6ex
ekk seems you got the carfox
Old May 10, 2011 | 10:11 AM
Downtimela's Avatar
Downtimela
My cars seller & a GM dealer told me that they are able to transfer the data from the original cluster to a replacement one when the need arises. I'm going to trust the mileage shown at this point.
Old May 10, 2011 | 10:34 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
That sounds right. I remember reading that if you had to change you gauge cluster, a GM dealer could transfer the original mileage from the old cluster to the replacement cluster.
Old May 10, 2011 | 10:42 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
...the problem is what if you want to show a lower mileage when it came time to sell and did not convert the data? The OP may have an 02 with higher mileage after the original owner swapped in a low mileage instrument cluster from a 50th anniversary garage queen involved in an accident. I know many Corvette parts shops that sell these parts after obtaining the salvage title.
To 02 50th ann...??
