Ipod connecting
Old May 10, 2011 | 12:33 PM
chrisk92's Avatar
chrisk92
Suspended by request 16 May 2012
Default Ipod connecting
When I got done plugging my ipod to the car it says on the ipod that its not supported. anyone else have this problem is a ipod touch 32gb 4th gen
Old May 10, 2011 | 01:56 PM
MCVetteLs6's Avatar
MCVetteLs6
different cords/ accessories and different ipods/iphones have different DC
basiclly the older accesories/ iphone/ipod run off a Firewire-based (+12VDC) conector
newer ipods run off a USB-based (+5VDC) connectors.
"Without any warnings to their millions of customers, Apple have changed the charging circuitry of their new devices so they only accept charging from USB-based (+5VDC) chargers. Earlier i-products also could charge through Firewire-based (+12VDC) chargers as seen in many car-installations and integrated iPod speaker systems. "
basiclly its either your trying to run a newer 5dc ipod/iphone through a 12 dc connector
or vise versa.
if it used to work and this is something new to you and it has always worked before then there is a few possible problems..
1. there is a problem with the cord, a cut or split or its just getting old.
2. the connector on the cord or the inside of the ipod/iphone is dirty and needs cleaning.
3. if you have jailbroken it, that would cause it to stop working sometimes.
hope this helps!
Matt
Old May 10, 2011 | 02:02 PM
chrisk92's Avatar
chrisk92
I havent jailbroke mines yet but i didnt know they change the cirucit of the charger thanks for the info thanks.
Old May 10, 2011 | 02:16 PM
MCVetteLs6's Avatar
MCVetteLs6
no problem!
Old May 10, 2011 | 09:39 PM
Jewjenk's Avatar
Jewjenk
Have you at least tried to see if it works anyway and if it charges?
A lot of accessories for the IPOD and the Iphone state not compatible but work anyway.
Old May 10, 2011 | 10:36 PM
VetteNoob's Avatar
VetteNoob
You can always get a 12v to 5v converter pass-through like the "iPod / iPhone Charging Adapter Converter (Black) - Convert 12V to 5V - Converts Old iPod Dock, iPod Alpine, Pioneer and Car Hook Ups to 5V Allowing You to Charge the New iPod and iPhones" by XTG Technology from Amazon.
http://www.amazon.com/gp/product/B00495JZTY
Old May 11, 2011 | 01:11 AM
stealthC513's Avatar
stealthC513
Mine says the same thing but it still sounds great and charges as well. No problems at all
Old May 11, 2011 | 01:34 AM
chrisk92's Avatar
chrisk92
It still play but not charging looks like i have to get a converter thanks for the input guys
Old May 11, 2011 | 08:23 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
your pxdp is older and you bought it used.
The older models will not charge the newer models.
You need a new ipod cable for this.
Old May 11, 2011 | 01:00 PM
chrisk92's Avatar
chrisk92
So the converter wont charge it still?
Old May 11, 2011 | 01:59 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
get a new cable, you'll be happy you did
Old May 11, 2011 | 02:10 PM
0Double D Mods
Former Vendor
no you have to have the 5v charging cable
there is 2 available would need to know size of what you have for the end that plugs into the pxdp
Old May 11, 2011 | 09:02 PM
VetteNoob's Avatar
VetteNoob
Can you explain why a 12v to 5v pass-through won't work? My existing cable will charge 12v iPods but doesn't work with my 5v iPhone. By theory shouldn't the converter work?
Old May 12, 2011 | 08:09 AM
0Double D Mods
Former Vendor
you kinda answered it
you need a 5v charging cable
a 5v charging cable will charge a 12v ipod as well but a 12v will not charge the 5v
Apple is the one who changed this a couple years ago. When Apple changed this PAC changed the kits to allow for the 5v charging to come with the PXDP
anyone who upgraded an ipod or to an iphone who had older kits had to buy the new charging or ipod cable for the pxdp
To Ipod connecting
