Springtime preventative maintenance done
Old May 10, 2011 | 04:25 PM
dcandel's Avatar
dcandel
Oldtimer
Default Springtime preventative maintenance done
Just finished having my springtime preventative maintenance done. Flushed cooling system & replaced coolant & thermostat, clutch fluid, new hoses, new belts, fuel filter and brake system flush. Now I'm ready for summer with peace of mind.
Old May 10, 2011 | 04:30 PM
JuicedZ's Avatar
JuicedZ
I did all that too with the exception of the fuel filter. Was that difficult?
I also did oil pump, springs, valve seats/seals/retainers, pushrods, cam, ls2 timing chain, headers, x-pipe and smooth coupler.
Old May 10, 2011 | 04:36 PM
corvettedaddy11's Avatar
corvettedaddy11
Where is the fuel filter located ?
Old May 10, 2011 | 04:40 PM
dcandel's Avatar
dcandel
Oldtimer
I don't know, all work (except clutch fluid) was done at the dealer. I'm mechanically inept.
corvettedaddy11
Found fuel filter , no problem..!
Old May 10, 2011 | 09:14 PM
VETSTYL's Avatar
VETSTYL
Default Semantics
Did you have the fluids flushed or drained & replaced? I don't know if there is a difference or is it just semantics.
Old May 10, 2011 | 10:07 PM
dcandel's Avatar
dcandel
Oldtimer
Yes, drained, flushed out & replaced coolant & brake fluid.
To Springtime preventative maintenance done
