throttle body by pass
Old May 11, 2011 | 12:23 PM
ohchiiit's Avatar
ohchiiit
Default throttle body by pass
is this cheap mod worth doing?
Old May 11, 2011 | 12:55 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Default depends
In my personal opinion:
Not if you spend $19.95 for the pre-made kit. You can buy what you need for $5 or less.
Not if your ambient temperature is usually very warm, say 80 or above (like me in FLA).
The bypass keeps your engine coolant from warming up the TB and makes your computer think it needs (or can make use of) more fuel.
If the IAT sensor is already sensing very warm air I think the usefulness of the bypass is neglible.
Someone else will disagree, i"m sure.
Old May 11, 2011 | 01:13 PM
damilleniumboy's Avatar
damilleniumboy
Buy a 6pk instead.
Old May 11, 2011 | 01:27 PM
dougbfresh's Avatar
dougbfresh
Wot
Old May 11, 2011 | 01:54 PM
chevy406's Avatar
chevy406
Bypassing coolant around the throttle body probably only makes marginal temperature difference to the incoming air when at operating temperature. But it certainly does make it easier to remove/replace the throttle body.
Old May 11, 2011 | 02:05 PM
sean.b's Avatar
sean.b
ive owned a bunch of cars that i've joined related forums for, and this comes up everywhere that a carb isnt involved. its all mixed opinion everywhere you go..
being as this is like $5, and these forums are still mixed, why has nobody logged before/after IAT temps? ill do the bypass and post before/after IAT readings sometime this month if nobody else has done it
Old May 11, 2011 | 02:31 PM
Paul 75 L82's Avatar
Paul 75 L82
That little U-shaped hose is a PIA to remove.
Old May 11, 2011 | 02:36 PM
1SGRET's Avatar
1SGRET
Old May 11, 2011 | 02:49 PM
2003Torch's Avatar
2003Torch
Don't bother.
To throttle body by pass
