[Z06] Rim/Tire Sizing Question
Old May 12, 2011 | 12:56 AM
MotoJB's Avatar
MotoJB
Default Rim/Tire Sizing Question
Will the following setup work on a lowered 2003 Z06 without spacers, and without any rubbing/brake duct issues?
18x10 fronts with 285/30/18 tires
18x12 rears with 335/30/18 tires
Thanks for the help!
Old May 12, 2011 | 02:17 AM
momo20's Avatar
momo20
the rears are gonna be to big i think ..are you running any wide body rear fenders?
Old May 12, 2011 | 12:35 PM
MotoJB's Avatar
MotoJB
Some guy is selling these claiming he's running them without spacers, without a wide-body kit and no rubbing issues. I was like, huh? Seems too big to me.
He says "You will have to remove the rear drake duct tubing. Not the outside piece, just the inside tube. Besides that, they didnt rub anything on my car. No spacers needed and I DO NOT have mini tubs."
Anyone have a link for a discussion around rim/tire sizing for Z06's? I did some searches but haven't found what I'm looking for yet.
Thanks again for any help.
Old May 12, 2011 | 02:01 PM
RC45's Avatar
RC45
What wheels? They might be custom offset CCW's that fit like a glove.
The 18x12's probably require removing the rear brake ducts though. And possibly the inner fender liner.
Fronts should not be a problem.
Old May 12, 2011 | 02:10 PM
MotoJB's Avatar
MotoJB
CCW Classics...
He says; "You will have to remove the rear drake duct tubing. Not the outside piece, just the inside tube. Besides that, they didnt rub anything on my car. No spacers needed and I DO NOT have mini tubs."
Old May 12, 2011 | 02:14 PM
RC45's Avatar
RC45
Originally Posted by MotoJB
CCW Classics...
Yeah, this is par for the course with any 12" rear wheel that you want to tuck under the fender on the Z06.
Correctly backspaced CCW Classics are, well, classic Take the plunge, you wont regret it.
Old May 12, 2011 | 03:01 PM
MotoJB's Avatar
MotoJB
Any negative consequences of removing the brake duct tubing?
Thanks!
Old May 12, 2011 | 03:33 PM
tlove32's Avatar
tlove32
Thanks!
None in my opinion. I had to remove my rear ducts to fit my ccw classics (18x12). And - I don't care what the person says, they will stick out just a tad. Mine stick out about 1/8" - 1/4"......
Old May 12, 2011 | 04:03 PM
MotoJB's Avatar
MotoJB
Thanks for the help tlove...
Old May 17, 2011 | 08:25 PM
MotoJB's Avatar
MotoJB
Guy's will I have any issues/problems with active handling if I upgrade to the following configuration:
18x9 front with 265/35/18
19x10.5 rear with 305/30/19
Please advise! Thank you.
Old May 18, 2011 | 12:23 PM
zeevette's Avatar
zeevette
That's close to my sizes....F-265-35/18 on 9.5" rims, and R- 325-30/19 on 11" wide wheels. No rubbing or cutting of ducts. The curved part of the sidewall sticks out about 1/4" tops. Depending of overall diameter differences between front and rears, your choices should work fine.
Old May 19, 2011 | 02:44 AM
striper's Avatar
striper
I'll tell you what I have for your reference. I have CCW Classics 18" front and rear. The fronts are 10" with 265/35's and the rear are 11" with 295/35's. My car is also lowered and I have not removed any ducting. My tires do not stick out, they are right at the wheel well edge. IMO they look perfect sitting right at the edge, front and rear. Most importantly for your info, nothing rubs anywhere. CCW does make 12" rears that will fit right just removing the rear brake ducts. Your can get more info on that by going to their website www.ccwheel.com. Hope that helps. Also, John, the owner of CCW can give you any info you need.
Old May 19, 2011 | 11:16 AM
MotoJB's Avatar
MotoJB
Thanks...I just talked to CCW, the lady put me on hold and went and asked someone...she said that although the 12" will fit after removing the ducting, they don't recommend a 12" rim on a C5 Z, saying the tire is going to stick out past the fender. They don't recommend going past a 11.5" rim in the rear on a C5. Hmmm...so much mis-information going around. Don't know who to believe. Guy's here are saying they don't have issues running 12" CCW's - say they don't have tires sticking out past the fenders...then CCW says don't do it.
Old May 19, 2011 | 11:36 AM
MotoJB's Avatar
MotoJB
Default CCW 12" rears...stick out?
What size tires are you running? Do you have any pics of how far they stick out? Do they look fine/good, or do they bother you? Any rubbing issues?
Please help! Thanks.
Old May 19, 2011 | 03:28 PM
pluslt's Avatar
pluslt
I'm running iforged Aero’s (19” on rear with 305/30/19 and 18” on front with 275/35/18) without any rubbing or active handling issues.
Old May 19, 2011 | 04:29 PM
MotoJB's Avatar
MotoJB
Cool, thank you plusIt.
Old May 19, 2011 | 10:31 PM
tlove32's Avatar
tlove32
I run 275/35/18 fronts and 305/35/18 rears. I don't have any pics, but if you're going to the Abel car show, you can see how they look. They don't rub at all, and the 1/4" they stick out doesn't bother me. Ig at some point I don't like the look, I'll order 2 outer lips to make them smaller. That's the beauty of a 3pc wheel.
Old May 19, 2011 | 11:23 PM
MotoJB's Avatar
MotoJB
Cool yes, I'll be there on Saturday...will look for you.
What brand/model of tires are you running?
Thanks.
Old May 19, 2011 | 11:49 PM
tlove32's Avatar
tlove32
Thanks.
Look for a silver z with black ccw classics. For tires, I run bfg's up front and nitto 555r2 extremes out back
To Rim/Tire Sizing Question
