Vacuum Leak
Old May 12, 2011 | 10:34 PM
cadman96's Avatar
cadman96
Default Vacuum Leak
2001 C5, 6sp, 23K. I have a whistling noise that develops around 2000 to 2500 RPM which from a hose test ( listening with a piece of hose) appears to be coming from underneath the front of the intake manifold. I know the PVC valve is on the side there and the whistle is not coming from it. Are there any vacuum connections underneath the manifold?
Old May 12, 2011 | 10:39 PM
StingrayRebel's Avatar
StingrayRebel
could be one of the intake port seals leaking... other than that there aren't any vacuum lines directly underneath the intake
Old May 12, 2011 | 10:48 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The way we use to look for a vacuum in the old days was to spray a little starting fluid around the motor and when the rpm came up you found your leak.
To Vacuum Leak
