Power Window Bladder
Old May 13, 2011 | 01:43 PM
galeslim's Avatar
galeslim
Default Power Window Bladder
I noticed that it was wet under the driver's seat and right side bolster does not seem to respond.What is my problem and how do I fix it? Is this liquid harmful to my 2003 Coupe ? Give me the bad news please !!
Old May 13, 2011 | 01:47 PM
Aerovette's Avatar
Aerovette
Uhhhhhhhh.....what?
Old May 13, 2011 | 01:53 PM
justanotherdoe's Avatar
justanotherdoe
Wet under the seat is never good, but I'm not sure (like Aerovette) i follow the rest.
Old May 13, 2011 | 03:49 PM
RedSoxFan's Avatar
RedSoxFan
Bladder problem + wet under seat = DEPENDS.
j/k but I'm not seeing the connection, unless your power switch and or/wiring got wet and is causing the bladder to stop functioning. Might want to hit the area with a hair dryer or something, if it works once it's dry then you need to identify the leak. Leaks around the windshield can be tricky and it could be puddling on your floorboard. Or maybe a clogged udder (below the cowl)?
Old May 13, 2011 | 05:01 PM
Aerovette's Avatar
Aerovette
Or maybe a clogged udder (below the COW )?
fixt
To Power Window Bladder
