Z06 brake duct mod?
Old May 14, 2011 | 08:59 PM
1BAV's Avatar
1BAV
Cruise-In IX Veteran
Default Z06 brake duct mod?
I'm getting ready to do the Z06 rear brake duct mod to my 01' vert. I think I've read enough about the job and am confident that I can do this mod myself. However, I thought I would solicit any tips or ideas from those of you who have already done the job to see if there are some ideas floating around out there that may not have made it to print.
This is how I'm planning to go about the job:
Remove the rear wheels and inner fender liner.
I've printed the template and have cut my pattern from a piece of cardboard. I plan to use the same one for both sides.
I am going to tape off the area with painters blue tape and then trace my pattern onto the taped area with a sharpie marker.
Could use some pointers on how to line up the template to ensure it is in the proper place.
I will then drill a starter hole in the area to be removed and then plan to use my jig saw with a fine tooth metal cutting blade to cut the hole. I considered using my Dremel as many here have done. I think I would have more control with the jig saw. Recommendations?
I was planning to use a pair of metal shears to cut the inner fender liner. I have an 01' so the fender liners should have the markings to trim the area for the ducts to fit through. Recommendations?
That's the meat and potatoes of the job, put it all together and life will be good!
Old May 14, 2011 | 09:17 PM
momo20's Avatar
momo20
sounds like you have it covered pretty well
Old May 14, 2011 | 10:11 PM
jrose7004's Avatar
jrose7004
I'd say you have! I used a skil saw on the inner fender.
Old May 14, 2011 | 10:43 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
if you are really nervous, try using a non power saw with some nice new blades to cut it.
it will be harder, and take longer. but the chances of screwing up is slim to none
Old May 14, 2011 | 10:46 PM
ALLEGRO's Avatar
ALLEGRO
I agree that slower may be better.
Good Luck
Old May 14, 2011 | 11:15 PM
vvf-16's Avatar
vvf-16
I did my 03, A starting hole, then a dremel works great with the carbide cutting bit, then a small drum sander attachment in dremel, (about 1/2 inch in dia), to smooth all out to a nice contour. For aligning the templates, I actually measured the distance from door contour to duct in three or four places from a Z06, and put my template at same location. Your idea of using metal shears is what I used as well, worked nicely. Take your time, measure twice...
Old May 15, 2011 | 12:09 AM
mcm95403's Avatar
mcm95403
When I worked at Flowmaster we always used to tell people "measure twice cut once".
I plan on doing this later down the road, so if you could post some pics, I'd appreciate it
Old May 15, 2011 | 08:56 AM
1BAV's Avatar
1BAV
Thanks for the info. I live by your quote "measure twice, cut once". It's just that I have found sometimes I can misread the tape measure twice, so I've started measuring three sometimes four times to ensure I've got it right. This would definitely be a time to get it right. There are no "do overs" here.
I plan to put some pictures up after the project is done.
You have a beautiful car. I love the Nassau blue. It's on my top five list with the top three all being blue. Thanks
Old May 15, 2011 | 02:01 PM
Evilash's Avatar
Evilash
Run shop vac with floor attachment pointed up at the work area. You will make a ton of dust.
I did the rotor cutting bit and it worked great. I couldnt imagine using a jigsaw at that angle and making a nice cut while the panel is vibrating.
Old May 15, 2011 | 06:04 PM
1BAV's Avatar
1BAV
I'll keep that in mind. I read a thread by a CF member who mentioned this idea in his thread. I couldn't believe how much dust was generated during the cutting.
I picked up a bit for my Dremel today. Think I will give the Dremel a try first.
Old May 15, 2011 | 07:06 PM
dankhts's Avatar
dankhts
it's not a bad job, not too hard, was going to do mine, but stopped by Manny's and he ended up wizzing through it before I knew it:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
the list you posted on how you're going to do it is exactly correct
Old May 15, 2011 | 07:09 PM
doublec4's Avatar
doublec4
Out of curiousity, what are the widest wheels you can go with before interfering with the ducting?
Old May 15, 2011 | 07:19 PM
dankhts's Avatar
dankhts
Anything that will fit a C5 Z06 will fit no problem.... I can't see how these ducts would interfere with any tire size - big fat tires/wheels will rub elsewhere before they ever touched the ducts....
Old May 15, 2011 | 07:22 PM
doublec4's Avatar
doublec4
Maybe I just have the wrong mental image of how the ducting is routed around the wheel to the braking area. I plan on doing this mod and have 295 tires in the back that I would like to eventually switch to 305s. Just want to make sure nothing rubs
Old May 16, 2011 | 01:06 AM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
Nice...when you do yours be sure and post some pics!
To Z06 brake duct mod?
