tire pressure
Old May 14, 2011 | 10:37 PM
dewaynemichael's Avatar
dewaynemichael
Default tire pressure
what is a good tire pressure for the summer months,today was the first really warm day in michigan and after getting off the highway my gauge keep saying high tire pressure from the road heat?
Old May 14, 2011 | 10:41 PM
O4-/-C5's Avatar
O4-/-C5
30 psi cold all around.
Old May 14, 2011 | 10:51 PM
Hammer99's Avatar
Hammer99
When they heat up, they will be at 32-33 lbs.
Old May 15, 2011 | 01:05 AM
That's the pressure I run.
Old May 15, 2011 | 01:09 AM
manley845's Avatar
manley845
30 psi cold
Why do you people not read the owners manual???? Summer, winter, it doesn't matter because 30psi cold is the correct setting.
Old May 15, 2011 | 01:18 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by manley845
30 psi cold
If you run 30 cold in the summer it can heat up to 35+ on asphalt and thats too much...I run 30-31 hot in my area and that means 27-28 cold for me
BTW...according to our resident C5 engineer...Evil-Twin...30 cold on the door sticker is generic...he knows what the real deal is...been following his expertise/advice for 10 years now...
Old May 15, 2011 | 07:49 AM
rws.1's Avatar
rws.1
I run 28 all around in the summer heat.... ie when it is consistently above 80. otherwise 30 psi cold all around.
Old May 15, 2011 | 09:22 AM
jrose7004's Avatar
jrose7004
30 psi cold at all times.
Old May 15, 2011 | 11:10 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
YES! to the summertime
I will be glad to take this off your hands anytime you get tired of it
Old May 15, 2011 | 11:36 AM
Jewjenk's Avatar
Jewjenk
30 psi cold
Cause that's too hard for them to do, they would rather think of posting something that's been posted over a zillion times without searching first and then expect a quick answer..............
Old May 15, 2011 | 06:59 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
In Arizona, I run about 26-27 cold with daytime temps reaching well into the triple digits. My net is about 32psi hot. Winter time, I run about 29 cold with close to the same net.
The point is you should run what works best in your climate. Too much is not better in this case.
As far as this topic being discussed about a billion times - yes it has. But not everyone remembers what's been discussed and what hasn't. And to be honest the search on this site is not the most user friendly. So I guess we can say if you don't want to help, then don't post and move on to another thread where you can make a contribution Also, many of these cars now have been through a couple of ownership changes, and strangely enough, the owner's manuals disappear. Aren't we all supposed to be on the same side here?
Old May 15, 2011 | 07:34 PM
snowbird12's Avatar
snowbird12
Does anyone run Nitrogen in their tires?
It should keep the pressures at what is set cold if you do.
We run it in our race car tires to keep stagger constant during the race.
Old May 15, 2011 | 08:15 PM
O4-/-C5's Avatar
O4-/-C5
I never knew Nitrogin did this.
Isn't this forum great - one question leads to another bit of knowledge.
Old May 15, 2011 | 08:35 PM
snowbird12's Avatar
snowbird12
From what I understand is that Nitrogen has very little moisture in it and the moisture is what causes the air pressure to rise, when hot..Also with less moisture , the aluminum rims do not corrode as fast, at the beads and the rim thus less leaks.
Goggle nitrogen , and get the story.
Jay Leno is all about Nitrogen.
I also have been told real air has a lot of Nitrogen in it, but pure Nitrogen is better.
I had it installed in my Tahoe tires in Fla , by a machine that takes out the air with a machine, then puts in Nitrogen with out removing the rims from the truck.
It does it 2 times to insure all the air is changed to Nitrogen.
Cost $39.95
Old May 15, 2011 | 10:35 PM
dewaynemichael
damn,what crawled up your a__? chill brother
Old May 15, 2011 | 10:36 PM
dewaynemichael
thanks for the info
Old May 16, 2011 | 12:32 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
To tire pressure
Old May 18, 2011 | 01:24 PM
SteveL4446's Avatar
SteveL4446
Yep!
Old May 18, 2011 | 01:45 PM
AfterburninC5's Avatar
AfterburninC5
Cruising
I would say whatever gets you to 32 psi when warmed up. Thats usually 28ish for me in summer, and 30 in the winter.
Old May 18, 2011 | 02:07 PM
CBackous's Avatar
CBackous
Cost $39.95
Air contains roughly 78% nitrogen. I guess the question would be "is the extra 22% worth the cost?"
I can see in a racing application, where tire pressure can be a big factor. for everyday driving, I cant see the benefit for the price.
