Old Feb 19, 2015, 07:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
Floppy passenger side mirror fixed!
Old May 15, 2011 | 06:13 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Default Floppy passenger side mirror fixed!
Well, the other day I was set to take the car out for a drive and noticed that the passenger side mirror was flopping around like a fish out of water. Upon taking it apart it is clear that this part of the C5 is a bad design. There is one flimsy retaining ring that holds the spring onto the post on the inside of the mirror. If that clip fails, you're in floppy mirror territory. I used the directions from this thread and they worked great:
http://forums.corvetteforum.com/c5-t...or-repair.html
I did do a few minor tweaks though. I didn't use a nail. Instead I used 1/8" stainless steel rod. Much more durable. I also took about 1/2" worth of steel out of the spring which made it easier to compress and use the bigger rod. From what I've read to replace the side mirror is about 4-500 bucks (plus paint). This fix saved me some $$$ and wasn't too hard. The mirror still pivots fine, but I won't mess with it and it should last a long time. Just use patience if you have to do this fix!
Old May 15, 2011 | 06:27 PM
jrose7004's Avatar
jrose7004
It's great that you got it done!
Old May 15, 2011 | 09:58 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Yeah, I figure that I can spend 500 bucks on a lot of other things besides a POS side mirror. I think that the side mirror breaking is about as common as the column lock or rocking seats.
Old May 15, 2011 | 09:59 PM
Congrats on getting it repaired. And nice tip on how to do the repair a bit different than others have done.
Old May 16, 2011 | 11:12 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
Thanks. I figured that I'd post this in case someone does a search and can't find much info about tearing apart the mirrors. I hate paying the Corvette tax, especially for such a bad design.
To Floppy passenger side mirror fixed!
