Please help with correct size!!!!
Old May 16, 2011 | 01:47 AM
Ruski Vert's Avatar
Ruski Vert
Default Please help with correct size!!!!
I just got my wheels from house of wheels 19x9.5 and 20x11 the fronts are 57 offset and fit perfect but the rears backspace is 8.48 when I put just the rim on and the car lifted, the clearance is about 1/4inch if not less by the wheel well and I don't know if i need spacer, and don't know what size tires I should get, I am ordering tomorrow Hankook Ventus v12
I have the car lowered about an 1.75 inch and don't want rubbing. Please help.
Old May 16, 2011 | 02:10 AM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
I think the proper offset for a C5 with 20x11 rims is 64. Not sure about the 8.48 backspace. I would call House of Wheels and make sure they sent you the correct rear wheels before mounting tires on the rims.
Old May 16, 2011 | 02:27 AM
Ruski Vert's Avatar
Ruski Vert
Sounds like a plan. Does anybody know what off set is with 8.48 backspace?
To Please help with correct size!!!!
