C5 coupe headliner problem need help
Old May 16, 2011 | 01:41 PM
sts57c5's Avatar
sts57c5
Default C5 coupe headliner problem need help
MY C5 headliner keeps falling down from my coupe hard top. I tried velcro but that did not work any suggestions on what i might use to bond it back to the top?
Old May 16, 2011 | 01:45 PM
Rob04C5LM's Avatar
Rob04C5LM
Upholstry adhesive. You probably need to remove it completely and then start over. I would even get a new headliner.
For some reason GM used really crappy adhesives on the interior of the C5s and as a result after 7-10 years people start having the door panels, headliners, dash pads, etc. start coming apart. If you get some good modern adhesive it will last a LONG time...
Old May 16, 2011 | 08:25 PM
sts57c5's Avatar
sts57c5
thanks
Old May 17, 2011 | 12:26 AM
SFL_driver's Avatar
SFL_driver
Just a thought but if you are going to pull the whole headliner and install a new one, suede (Alcantara) would look pretty sweet. I've actually considered doing it on my targa even though mine is in good condition.
Old May 17, 2011 | 07:42 AM
runner140*'s Avatar
runner140*
Did mine in August.....used 3M adhesive and it worked like a charm.
1. Pulled three sides down.
2. Sprayed 3M adhesive on the backing and let it set up..follow the instructions.
3. Re-attach the headliner and tuck in with something soft (like a popsicle stick).
Quick, easy job.
Old May 18, 2011 | 08:56 AM
sts57c5's Avatar
sts57c5
thanks will give it a try
To C5 coupe headliner problem need help
