Fuel pump upgrade
Old May 16, 2011 | 07:56 PM
Steven Ressue's Avatar
Steven Ressue
Navigator
Default Fuel pump upgrade
I need some info on a fuel pump upgrade. I'm looking for a new fuel pump to fit my 2004 driver side fuel tank. I have a new LS3 GM performance crate engine that requires a constant 400 kPa (60 psi) with the engine running, with a minimum 40 gph. I think the GM 2006 and newer pump might fit but not sure. I'm also not sure what the operating pressure is. Having trouble finding info on pumps that fit and pressure ratings. I think the 06 pump part number is 19133441. Any info would be a big help.
Old May 16, 2011 | 08:49 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You MUST get the 2003 (late model) up Pump, kits etc for the 2004 C5, that is when they started installing the same fuel pump system they would be using in the C6's
Fuel Pump: Walbro 255lph
http://www.racetronix.biz/itemdesc.a...%2D006&eq=&Tp=
Here is their full kit: Everything you need for proper fueling and voltage:
http://www.racetronix.biz/customkiti...RFPK%2D008&eq=
You can also install the drain kit:
http://www.racetronix.biz/itemdesc.a...K%2DC5&eq=&Tp=
Thanks,Matt
