Headlight problem
Old May 16, 2011 | 10:17 PM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Default Headlight problem
2001 C5....Headlights open when switch is turned on....when switch is turned off, they close, but the drivers side immediately pops back up....Tried a new headlight switch but it didnt help...Any ideas??
Old May 17, 2011 | 03:51 AM
Jistari's Avatar
Jistari
Nope, but the headlight controller is attached to the fenderskirt under the pass side headlight (plastic 4 x 4 inch, screwed to skirt, several connections plugged in). You may be able to get to it from underneath to see if the connections are all tight and not corroded. Just an idea until someone who actually knows what he's talking about shows up.
Good luck
