And the insanity continues....
Old May 19, 2011 | 12:03 PM
Rob04C5LM's Avatar
Rob04C5LM
Originally Posted by MSG C5
I still think the Racemesh is better than both.
http://www.customcorvetteaccessories...tegrilles.html
That price is rediculous!
Old May 19, 2011 | 12:09 PM
Ron C!'s Avatar
Ron C!
GM has really kicked the price of C5 parts up. For example, I needed the side pieces of weatherstrip for my solid top. I priced them last May @ around $80 per side. When I went to order them in September the rise had jumped to nearly $190 per side. I ordered repro's from Corvette Central for $99 for both sides, the quality was as I would expect OEM to be. Most likey made by the same vendor that supplied GM. I had no problem using a like quality reproduction at 1/4th the cost.
Old May 19, 2011 | 01:32 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
That sucks!!!!!! I took a golfball size rock to my passenger grill and the mesh is F&*%$ up pretty good. The frame is still ok, I'm just going to order new mesh and fix mine for that crazy price!
I'm glad that I had the screens, otherwise that rock would have hit my intercooler. That would be a $1200 problem!
Old May 19, 2011 | 01:54 PM
CorvetteCentral.com's Avatar
CorvetteCentral.com
Platinum Supporting Vendor
For a C5 vert, can you use the mounting tabs or do you need to use double-sided tape/velcro? How difficult of an install is it to use the OEM mounting tabs? Does the front fasica need to be removed or can you get to the tabs from underneath or through the light buckets?
You would need to use the double sided tape that is included with the grills. The non-Z06 C5's do not have the corresponding holes to utilize the mounting tabs.
Old May 19, 2011 | 09:23 PM
angman5's Avatar
angman5
Hey I think that is hand delivered by an escort wink wink
