C5 Roof?
Old May 17, 2011 | 09:41 PM
BobS3501's Avatar
BobS3501
6th Gear
Default C5 Roof?
This my first post and image attachement so I hope I got this right. I have a 1997 Arctic White Coupe that is getting me through my midlife crisis. I recently purchased a painted targa top to replace my top and was told that the top came off a 1997 Arctic White Coupe. The top is in great shape but it appears to me to be a C4 roof as it looks identical to my brother's 1995 roof. If the image has come through on this post, could you give feedback as to what this roof would fit? Thanks
Bob
Old May 17, 2011 | 09:44 PM
Myblue2000's Avatar
Myblue2000
Bob, indeed this is the roof from a C4
Old May 17, 2011 | 09:49 PM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
Definitely not a C5 roof.
Old May 17, 2011 | 10:28 PM
jrose7004's Avatar
jrose7004
Yep.
Old May 17, 2011 | 10:33 PM
95wht6spd's Avatar
95wht6spd
C4 I have one. The 84s are different size, so that probably fits 85-96. If that nice on the other side you can probably get around $500.
Old May 17, 2011 | 11:32 PM
OkieBikerDude's Avatar
OkieBikerDude
It is a top for a C4 and will require a torx wrench or the factory ratchet to install/remove. It will not fit a C5.
OBD
Old May 17, 2011 | 11:40 PM
imavettegirl's Avatar
imavettegirl
that is a c4 roof.
the roof sizes are the same, the mount had different designs.
Old May 18, 2011 | 10:41 AM
You're right, that is not a C5 roof but instead a C4 roof. The C4s used a ratchet wrench to tighten the panel down where the C5 uses three pull latches to do the same job.
Old May 18, 2011 | 10:44 AM
jerrymcb's Avatar
jerrymcb
A c5 roof would have a latch on both front corners and another small one in the middle of the rear.
Old May 18, 2011 | 11:46 PM
BobS3501's Avatar
BobS3501
6th Gear
Thanks for the feedback, guys.
To C5 Roof?
