Air dam fasteners ?
Old May 18, 2011 | 01:31 PM
killain's Avatar
killain
Oldtimer
Default Air dam fasteners ?
I recently bought a set of lower air dam clips and bolts? I ask because the air dam sags at the corners, so I bought what is advertised as a "Reinforcement" from one of our sponsors. What a waste of money,it is nothing more than a plastic curved piece, and the listed bolts or fasteners are 6mm and the fasteners take a sheet metal screw? Ray Charles could see there is no way these bolts/fasteners could every fit together ? I'm sorry I ever took on this job.
Old May 18, 2011 | 01:43 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I have those similar curved supports and I'm happy with them as they did lift up the sagging OEM corners. I used the OEM fasteners already used for the corners. I simply installed the plastic curve reinforcements underneath the corners and then reinstalled the OEM screws and the seem to work fine.
Maybe your OEM screw holes are stripped which is causing both the flex spoiler and the curved supports to sag.
Old May 18, 2011 | 02:02 PM
mcgilles's Avatar
mcgilles
I drilled a couple holes through the air dam and the bumper cover and used 3 pop rivets in each side spaced evenly around the area which sags. problem solved. total cost about $0.05
Old May 18, 2011 | 02:44 PM
killain's Avatar
killain
Oldtimer
Default Air dam fasteners !
Well I'll have to try the 'plastic corners reinforcement' part. Maybe it'll work, but I think I'll have to just drill a 3/16 hole and put a sheet metal screw to pull it up. Problem is my own, my driveway always drags a little in and out. So it's my own situation that's all. I bought a all new set from Gene at GMpartshouse.com already.
Old May 19, 2011 | 10:06 AM
eldudereno's Avatar
eldudereno
I've just been sorting mine out today as well as trimming 1 inch off the bottom. Some washers of approx 3/4" diameter and some self tapping screws work just great. You'll find that it's best if you remove the outer OE screws and put a screw/washer further into the end corners to pull them up nice and tight.
To Air dam fasteners ?
