Window looseness!! Advice Please
Old May 18, 2011 | 05:48 PM
wascapsfan's Avatar
wascapsfan
Default Window looseness!! Advice Please
I have a loose passenger window. from front to back it is perfectly aligned but from out to in it is loose. If I have the door closed and the window open half way...If I stand outside the window and grab the center of the glass from the top, I can move the glass in towards the car and back out towards the outside.
Is this something that needs the door panel removed and some track work or is this a tightening of something from underneath the door..?
Please Advise!!!!!
Old May 18, 2011 | 06:04 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
If I'm understanding you right, it sounds normal. There is play when the window is half way up. If it more than the normal play then I would check the bolts that hold it in place. One is behind the reflector on the door and the second is behind a rubber grommet under the door towards the front of the door.
John
Old May 18, 2011 | 06:08 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Old May 18, 2011 | 06:38 PM
You will have some play in the window as far as the in/out movement goes - just like on any car. I may have some Word files that talk about window adjustments - if you'd like a copy, PM me your e-mail address.
To Window looseness!! Advice Please
