Another Window Tinting Question
Old May 18, 2011 | 11:06 PM
gwalker's Avatar
gwalker
Default Another Window Tinting Question
Went to a shop today and they suggested that they install a vinyl material at the top of the rear window where all the little dots are. I would not be able to see through this material. They said that they would put the seam at the top of the last rear defroster line and that I could not see the line. They stated that just putting tint over the little dots is hard to get perfect. They said they would do it either way that I wanted. I wish that I could remember the exact name but it is LLumar.
Has anyone ever used this product?
If so any visibility issues?
Thanks for any input.
Old May 19, 2011 | 12:08 AM
SFL_driver's Avatar
SFL_driver
The problem is that where those dots are there is more dot surface area than glass surface area so the tint has a hard time sticking to the window. The tint wont fall off but you end up getting a lot of area where air is still under the tint and you don't get the nice black look. I feel like I didn't explain that last part very well so here is a picture of what I mean. Hope this helps give you a better idea of what you are getting. My tint is also Lumar tint.
If you look at the top of the window you can see where it looks lighter. That's what will happen if you just use tint. I have tried going in there with a credit card and some other stuff but it just won't stick. I'm happy with it though.
And before anyone comments... I am in college and the EX stands for Sigma Chi.
Old May 19, 2011 | 12:17 AM
momo20's Avatar
momo20
my brother has on his camaro..and to be honest it looks like ***...it was on the car when he bought it..2002 z28 with 31,000 miles...the whole car is show room perfect..all for that **** on the back glass..
Old May 19, 2011 | 12:32 AM
dba4life's Avatar
dba4life
Shop was able to make mine look perfect with Formula One Pinnacle tint. I specifically asked them about this section and they said it took a special technique to make it look right.
Old May 19, 2011 | 12:34 AM
SFL_driver's Avatar
SFL_driver
Do you know what this technique was? I would like to fix mine if there is a way.
Old May 19, 2011 | 12:42 AM
Rob04C5LM's Avatar
Rob04C5LM
The vinyl strip is very common on the dot matrix areas of cars. If the installer does it right, you won't notice any difference. Mine has it and I would defy anyone to find the line from the outside of the car. Only works with high-quality 5% tint. If it's lighter you'll see the strip.
Old May 19, 2011 | 03:05 AM
JETZ's Avatar
JETZ
^ Had the black vinyl done on mine too.
http://www.tintdude.com/dot-matrix.html
Old May 19, 2011 | 09:10 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Personally I would take the advice of the experts.
As a side note I'm having my FRC tinted today, and wouldn't you know it's raining!
Old May 19, 2011 | 09:16 AM
myc5toy's Avatar
myc5toy
Great stuff! Specialty shop here,http://tommypikecustoms.com/, has the pinnacle stuff and it is the best stuff out there. It is a ceramic impregnated film. Wont fade, colorize or scratch easily and is made to conform to shapes better.
Old May 19, 2011 | 12:07 PM
02blackLS6's Avatar
02blackLS6
I just had my windows tinted and had my installer use a vinyl strip across the dot matrix. With 5% tint on the back window, you can't really notice a difference between the tint and the vinyl when you're looking at the outside of the car.
Although you can apply tint over the dot matrix and make it look decent, I've had several friends complain about the tint pealing off the dots, later down the road.
Old May 19, 2011 | 12:14 PM
pluslt's Avatar
pluslt
The guy who I have asked to do mine also mentioned this as an area for concern. Said the tint doesn't stick to it well. He mentioned painting the area with some sort of tint paint. I'm not going that route,but it sounds just like what you are looking at except permanent which is why I'm not doing it. I think I'll be OK with the tint looking odd around the dots.
WTF are those damn dots for anyway?
Old May 19, 2011 | 12:26 PM
dba4life's Avatar
dba4life
I am sorry that I don't know. I left it to him
Old May 19, 2011 | 08:21 PM
musicmankeb's Avatar
musicmankeb
I tint windows on the side, if you want your rear window to look right then go with the vinyl over the matrix. Most tint will not lay down over the factory dot matrix correctly and you'll have a random lighter area. It looks like crap. Vinyl for the win!
Old May 19, 2011 | 08:40 PM
johnsos30's Avatar
johnsos30
My car looks like the picture above. My only saving grace is that my car is black with 15% so it's hard to notice the dot matrix at the top of the window since everything is practically black. If I knew about the vinyl strip, I would have had that done to the top.
good luck and you'll regret putting window tint off so long.
Old May 19, 2011 | 08:47 PM
gwalker's Avatar
gwalker
Thanks for the information. I will post a picture next week with it on there and get the exact name and give you my .02 worth.
Greg
Old May 19, 2011 | 11:10 PM
SFL_driver's Avatar
SFL_driver
I think they are for heat dispersion to prevent cracking, but I could be wrong.
Old May 20, 2011 | 12:02 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
I just had my FRC done a few weeks ago and they did the blackout strip at the top.
You don't see it when you look throught the rear view mirror and like previously stated, it should stick to the dots better.
Time will tell.
To Another Window Tinting Question
Old May 20, 2011 | 12:33 AM
Qwik01's Avatar
Qwik01
I had mine tinted a couple months ago. They tinted right over the dots. They did tell me to rub my finger on it a few times a day for the first week to squeeze out any moisture that is in there. I did that a few times a day and mine is lookin good!
Old May 23, 2011 | 08:09 PM
03z06eb405's Avatar
03z06eb405
I had my windows tinted about 7 years ago and the installer installed the tint right over the dots. So far no problems and the tint looks good,
Old May 24, 2011 | 11:38 PM
gwalker's Avatar
gwalker
I just got my car back late today and took a few photos. The vinyl at the top where the bubbles are is called Dotrix, LLUMAR brand. I know it is there, otherwise it would be hard to tell from the outside. I did go with 15 on rear and 30 on sides.
Here is a photo from what it will look like from inside. I just drove it home, but sure did not interfere with the rear visibility. Looking through rear-view mirror could just see a thin black strip, now when you look over your shoulder it is noticeable, but like I said does not obstruct your view.
Close up on rear, if you look you can see the color difference.
Hear is another, just because I am so glad that I did my first MOD. HaHa
