Suggestion
Old May 23, 2011 | 01:31 AM
El original's Avatar
El original
Default Suggestion
I always have my (24k miles) Vette serviced at my local GM dealer, oil etc., well when GM does oil changes air cleaner inspection is included right! I just installed a new air bridge and in doing so the air filter housing poped open exposing the air filter which was filthy. I promptly replaced it and my Vette feels like a new car, idles 150-200 rpm faster and a jump off the get go. I suggest you check your filters and don't depend on your service guy. Easy as pie. Rob
Old May 23, 2011 | 01:48 AM
ljthe2nd's Avatar
ljthe2nd
That's why I do my own work.
Old May 23, 2011 | 08:34 AM
runner140*'s Avatar
runner140*
Most of us use the same service guy....the owner.
Old May 23, 2011 | 09:04 AM
76 VETTE's Avatar
76 VETTE
I always do my own service work.just don't trust the dealers.
jrose7004's Avatar
jrose7004
That's another reason to stay away from dealerships.
Old May 23, 2011 | 12:27 PM
Did you check with the dealer and make sure they include a check of the air filter - maybe they don't do it there. In any case, I agree with the others - that's a good enough reason to do the work yourself if you can.
Old May 23, 2011 | 02:21 PM
El original
Yes, they have a check list included with everything from tire pressure to powersteering level and top-up, there is a entry for air filter check..so I took it at their advice it was fine, I am thinking because of the low mileage they skipped it, I was surprised and had a thread posted last year asking why my car was ideling so low ~650 RPM, now I know why. I will double check everything after next oil change. (If you bring you own oil and filter cost is $25- for oil change, will not do it myself for that and what to do with old oil filter etc.?) Greetings, Rob
Old May 23, 2011 | 04:26 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
at the very least i know what work was performed
Old May 23, 2011 | 04:45 PM
UM Rebel's Avatar
UM Rebel
I'm a little surprised changing air filter would affect idle speed. Thought that was controlled by PCM.
To Suggestion
