Engine won't turn over, HELP
Old May 25, 2011 | 06:57 PM
FourG63 97GST's Avatar
FourG63 97GST
Default Engine won't turn over, HELP
It happened intermittently twice in a month or two.
basically, the starter won't engage.
so far I'm tried jumping the clutch switch, no luck so far, any more tips?
Schematics?
Note, I can jump start it and it runs fine, so it's Ignition/starter related, I'm also not even getting the "click" from the starter
Old May 25, 2011 | 07:06 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
Sounds like it could be a bad battery connection.
Old May 25, 2011 | 07:27 PM
cdkcorvette7's Avatar
cdkcorvette7
Hard to diagnose just from that description... First thing to do as already mentioned is to check the battery connections, make sure they're nice and tight and not corroded. You could also have a bad ignition switch (pretty common problem) do a search for ignition switch repair and look for bill curlees thread; it's not a bad job. I had to do it to mine a couple years ago. You could also have a failing starter or starter solenoid.
Do you have any codes?
Old May 25, 2011 | 07:56 PM
FourG63 97GST
Thanks, Reason I dont think it battery related because there was no warning, or corrosion, I left the house fine, went to the atm, tried to start and got nothing.Jump started then drove home.
So far I will eliminate the actual ignition switch and clutch pedal switch.
I'm getting feedback at the passenger footwell, I hearing a click down there which should be a the bcm or some relay.
I'm going to check an signal to the starter seloniod, that should be the last electrical "stop"
I found this Schematic, it's a 98, but should be similar
Old May 25, 2011 | 08:20 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I would look for loose grounds.
My $00.02
Old May 25, 2011 | 10:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the battery connections and the battery ground connection to the block. Check the solenoid connections. How old is the battery?
Old May 26, 2011 | 10:51 AM
Phanni's Avatar
Phanni
If a jump bypasses the problem, it is 99% that you either have a bad connection or a bad battery. Clean and tighten your terminals, do not over tighten, and try again. If this doesn't do it, take it to a battery shop and have your battery tested. The C-5 can be hard on bateries if you don't drive daily. Old batteries can also give you problems.
Old May 26, 2011 | 11:15 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
The only thing a jump start can cure is a bad battery or bad connections to the battery. All the other electrical items are immediately ruled out.
Take it to an auto parts store and have the battery checked - IN THE CAR. That should find a bad connection (if there is one) at the same time.
GL
Old May 26, 2011 | 03:37 PM
OkieBikerDude's Avatar
OkieBikerDude
My money is on a bad battery, with battery connections being a close second. I've driven a car for two hours at highway speed stopped for a gas/snack/restroom break and the battery was so dead I didn't get a "click" when I tried to leave - internal short in a battery will kill it quick.
OBD
Old May 26, 2011 | 04:11 PM
Fast one's Avatar
Fast one
You should check the total current drain on the battery at rest, it should be about 30 ma after a minute when all the circuits are off. If a circuit stays on all the time when it should be off it can drain the battery enough so the car won't start until the battery is charged or jumped. The current won't be zero because the computers are always on causing the 30 ma drain which is normal.
Old May 28, 2011 | 10:02 AM
FourG63 97GST
did the good ole beat on the starter trick, cranked right up
Old May 28, 2011 | 01:18 PM
dgrant3830's Avatar
dgrant3830
Then its time for a solenoid
Old May 28, 2011 | 05:46 PM
LoneStarFRC's Avatar
LoneStarFRC
Or at least see if the cable connection is tight.
I've seen quite a few threads here over the years from guys that had had loose battery cable connection at the solenoid. A loose ground connection on the side of the block can cause issues also.
To Engine won't turn over, HELP
