need antenna advice
Old May 27, 2011 | 01:23 PM
Tom Hudson's Avatar
Tom Hudson
Default need antenna advice
I tried search without success - must have been talked about before - anyway - I would like to remove my power ant. On my 01 C5 convertible & install a fix 8 or 10" black shorty ant. Is there a kit out there I found a couple for the C6 but haven't found anything for the C5?
Old May 27, 2011 | 01:39 PM
65GGvert's Avatar
65GGvert
Why not just run it down and unplug the power connector. It will still pick up, probably as good as the rubber shorty. Then if you change your mind, just plug it back in, or put a switch in line with the power wire so you can choose.
Old May 27, 2011 | 02:40 PM
Tom Hudson's Avatar
Tom Hudson
Because I like the looks of the short black antenna - simple as that - I don't want a rubber shorty I want a black steel shorty.
Old May 27, 2011 | 04:10 PM
SaberD's Avatar
SaberD
i like my giant stock non-power antenna. it makes it look like an RC car.
Old May 27, 2011 | 04:57 PM
Tom Hudson's Avatar
Tom Hudson
You know what - Thats just what I was think-in
Old May 31, 2011 | 01:15 AM
Razzputon's Avatar
Razzputon
Give a call to Marc and Eddie at Vettenuts.com. Ask if they have a Z06 Antenna base. It will fit a Vert. I was going to go that route but I decided to cut the pink wire that controls the up/down on the antenna and installed a toggle switch. This helps a lot if you have a satilite reciever and use the frequency modulator to connect to you radio. If you leave the antenna down you will never get an outside reception.
Old May 31, 2011 | 01:23 AM
momo20's Avatar
momo20
hahaha..i think the same thing when i look at my Z!
Old May 31, 2011 | 01:26 AM
Tom Hudson's Avatar
Tom Hudson
thanks - i'll give them a call - tom
Old May 31, 2011 | 07:46 AM
melvingregory's Avatar
melvingregory
When I installed L5 fenders on my vert, I shaved off the power antenna, rear markers and installed a fixed antenna behind the rear bumper. I have noticed no difference in reception.
Old May 31, 2011 | 03:57 PM
yyzmsp's Avatar
yyzmsp
From: maple grove and North Port fl mn and now florida
melvingregory, where did you get your antenae. I did this with a wire flexible antenae and the reception is ok in the city but is crap on the road. Thanks Rick
Old May 31, 2011 | 04:11 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
http://forums.corvetteforum.com/c5-g...delivered.html
Old May 31, 2011 | 04:45 PM
Tom Hudson's Avatar
Tom Hudson
I'm about ready to give up & cut the damn wire! I just got an e-mail from a vendor & was told a lot of guys tried this mod but without any luck?
Old May 31, 2011 | 05:27 PM
Evil Oil Apologist's Avatar
Evil Oil Apologist
Installed a black shorty a few years back. Works just fine. An added win win is that it faded to a nice silver color that matches my Z06. Sweet.
Old Jun 2, 2011 | 04:11 PM
Tom Hudson's Avatar
Tom Hudson
I'm a little pissed - Replacing the power ant. With a shorty is a little bit of a hassle- ZO6 base & tall antenna must be bought together - 70 bucks - Shorty antenna to replace the tall antenna 20 bucks - so that’s 90 bucks -
So I ordered a new mast from flea bay for 20 bucks - my old one has a slight bend in it -
So today I go after the famous pink wire - Take out the tail light - Yep there it be - I go up front to the passenger floor board area - Yep - I found it in a maze of other wires -
I made a new wire loom to run to the console - Buy a toggle switch -
I cut the "PINK" wire - Turned the key on - Turned on the radio - Yep my antenna goes up like it digested 2 little blue pills - Turned off radio - Yep antenna went back inside not to appear until it's needed again.
So now I think I’ll just join my PINK wire back together and call it a day, unless someone can tell me what I did wrong?
Thanks - Tom
To need antenna advice
