electrical issue
Old May 28, 2011 | 01:24 PM
J Moody's Avatar
J Moody
Cruising
Default electrical issue
on a 98 convertable...dash board lights up, fuel pump turns on, BUT have power to nothing else will not crank, no radio, no dome lights, and such...battery good & terminals are clean, checked the charging system all is good, when you losen the battery terminal the lights will come on and you can start car, then runs fine. turn car off and try to restart if you let sit for 10 min then would have to losen terminal to restart car again...also key fob is not working with car...checked grounds cant find any corosion. Also i put my snapon modis on car and no codes come up... think there may be a issue with the alarm? is there a way to bypass the alarm or could there be a diff issue?
