[Z06] Cigerette lighters not working
Old Jun 2, 2011 | 01:40 PM
Zosixin's Avatar
Zosixin
Default Cigerette lighters not working
Both my Cig. Lighters are out. Anyone else have this problem?
Is it a blown fuse?
Old Jun 2, 2011 | 02:12 PM
imavettegirl's Avatar
imavettegirl
you did check fuse, right?
Old Jun 2, 2011 | 02:14 PM
bumble-z's Avatar
bumble-z
The cig lighter fuse is located in the fuse box on the pass side
on the upright carpeted panel.
Pull the pallel & take the door off the box.
It is # 7 fuse, which requires a # 20 mini fuse. It will be a light yellow in color .
If that isn't the problem, you may want to pull the radio bezel out, along w/ the console to get to a possible loose wire on the cig lighter.
Good luck.
Old Jun 2, 2011 | 02:25 PM
Evil Oil Apologist's Avatar
Evil Oil Apologist
Also, stop smoking.
I keed, I keed.
Old Jun 2, 2011 | 02:46 PM
Zosixin's Avatar
Zosixin
Good luck.
Thanks, I'll look at that fuse.
Old Jun 3, 2011 | 01:05 AM
Zosixin's Avatar
Zosixin
Good luck.
It was a blown fuse, thanks.
Both are working now.
To Cigerette lighters not working
