I need a stall converter
Old Jun 2, 2011 | 01:49 PM
STLSPARKY's Avatar
STLSPARKY
Default I need a stall converter
I'm putting 3.42 gears in my A4 I'm considering putting a stall in it. Thinking about the astro van replacement, the highest I want is 2800rpm nothing real loose, the car is a cruiser not a drag racer. Anyone know of a place to get a one for a good deal on a budget? <$400 I'm looking at around 400hp for awhile and don't mind a rebuilt one. Will a Camaro/firebird 6l80e model fit?
Old Jun 2, 2011 | 03:10 PM
msgvert's Avatar
msgvert
Check this site out:
http://torqueconverter1.com/
Old Jun 2, 2011 | 04:12 PM
STLSPARKY's Avatar
STLSPARKY
$130 for a rebuilt stocker with a 2800stall. Works for me, thanks!
Old Jun 2, 2011 | 04:18 PM
sean.b's Avatar
sean.b
wow, is that reliable? thats super cheap.. may do that myself if its reliable.
Old Jun 2, 2011 | 05:17 PM
STLSPARKY's Avatar
STLSPARKY
I hope it is.. its a stocker thats been loosened up. should be the same converter that's in the older 4L60E pickups, it has a 1yr/12k mile warranty.
Will I need a bigger transcooler with that converter?
Old Jun 2, 2011 | 05:37 PM
sean.b's Avatar
sean.b
adding the 2800 stall wouldnt warrant a cooler by itself. only need that if you're really beating on it or if your temps are already above 200 and you're adding more to it. there's plenty of posts here going into that, though.
Old Jun 2, 2011 | 06:00 PM
STLSPARKY's Avatar
STLSPARKY
So what's a safe temp range to run 180-230?
Old Jun 2, 2011 | 06:02 PM
sean.b's Avatar
sean.b
bunch of posts about that here too i try to keep mine under 200 personally. i havent added a trans cooler/fan yet, although i've purchased one.
easiest thing to do for a mild setup that probably suffices (i say PROBABLY) would be a 160 degree thermostat, retune the fans down, add water wetter, and change your trans filter with your maintenance. the tranny is cooled through the main radiator in the car, so lowering those temps lowers the tranny temps.
again, there's a LOT of threads on this.
To I need a stall converter
