Make your own Jacking Pucks CHEAP!
Old Jun 6, 2011 | 10:18 PM
wetelvis's Avatar
wetelvis
Strange in Canada the pucks are $1 and the I bolt was 2
Old Jun 6, 2011 | 11:44 PM
Laser Guided's Avatar
Laser Guided
i will have to do this soon...
Old Jun 7, 2011 | 02:19 AM
Rebel 1's Avatar
Rebel 1
I checked Walmart, Dicks and Play it again, no luck no pucks.
Found them at Purehockey.com for $2.00 ea. Shipping was $4.00 for all 4.
Got the bolts at Tractor supply for $1.00 ea.
Bob
Old Jun 7, 2011 | 02:13 PM
zuli's Avatar
zuli
How much are the BMW pucks and which is the part #.and are the same for C6 ?
Old Jun 7, 2011 | 02:28 PM
Rob04C5LM's Avatar
Rob04C5LM
hmm...just out of curiosity, why do you need the eye bolt? Seems like if you position the jack and the hockey puck correctly the eye bolt is unnecessary...unless it is intended to stabilize the puck from sliding around.
Old Jun 7, 2011 | 02:31 PM
my50thAE's Avatar
my50thAE
Default Puck Pics
Pics of pucks please...say that 5 times fast!
No seriously, does anyone have pics of the pucks installed or in use with their jacks?
Old Jun 9, 2011 | 10:53 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
The eyebolt fits into the slot to make sure the puck is positioned perfectly in the center.
Old Jun 9, 2011 | 10:58 AM
Rob04C5LM's Avatar
Rob04C5LM
Thanks, I've got a set of the jacking pucks and I get how the positioning works, I was just curious if they were absolutely necessary or if you could just be careful in your positioning. Probably better safe than sorry anyways.
Old Jun 9, 2011 | 05:08 PM
bighank's Avatar
bighank
Default If you do it right you put it in and make a 90 degree turn to hold it there
I don't leave them in but when jacking insert the eyebolt and turn it 90 degrees. Mine hold snug. When I'm done I remove them and keep them in the left compartment in the trunk so I have them if I need to jack the car up away from home. BIGHANK
Old Jun 9, 2011 | 05:23 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default From the Ultimate DIY Sticky in the C5 Tech section
Here you go......I posted this about a year ago, there are many more also ....
http://forums.corvetteforum.com/c5-g...ck-thread.html
Old Jun 9, 2011 | 06:05 PM
SG Lou's Avatar
SG Lou
I made my own jacking pads using 4 hockey pucks and 4- 2 5/8" Lag eye screws. Drill a 1/8th" hole in the center of the puck to make screwing the eye bolt a little easier. Screw the eye bolt down until the "eye" portion just touches the top of the puck. There will be about 2 to 3 threads of the eye bolt protruding through the bottom of the puck. I ground that down on a bench grinder. The eye bolt will fit into the slot of the frame and if you didn't screw it down too far you can actually turn and "Lock" the puck into place in the frame slot.
Total cost...around 7 bucks and it works great !
