Hey step 10 in removal for oil pressure sensor, I thought about placeing a plier on the bolt bottom that is exposed and cutting off the top? Then just getting new ones to replace them any Idea on the part number for 98 was told the engine ls3 instead of the example of the ls2 or 1. All stock as far as I know!!! Is this possible? Far back bolts. They just wont come up far enough to remove. Everything step by step and still wont give!!
What is the general thought on this?
Thanks in advance
Oh and if I do this measure how would they go back in properly? What in the world? New a bulider of the beast to tell me something? Other than the entire engine come out LOL
Are you certain it's the bolts? Your original thread provided suggestions on what possibly is the issue.
There is no real need for a duplicate thread on the same basic technical issue. Just update your original thread. It's easier for other members to follow along with your situation, suggestions and ultimate remedies.
If you need to find your past threads, click on your user name and scroll down your profile page. There's a link that will direct you to all of your past threads/replies.
The C5 Tech sub forum would be a better place for your questions. But good luck with it. I'm sure someone else will find useful information in your thread.
