How do you lower a car?
Old Jun 8, 2011 | 09:54 AM
dc5vette's Avatar
dc5vette
Default How do you lower a car?
I recently had new wheels and tires put on my car and after posting pics, it was recommended that I should lower my car to reduce the gap between the tires and the fenders. Any suggestions on how to do this without having to resort to coilovers? Also, what kind of negative effects could this produce if not done correctly? Thanks in advance! Here's a pic, and thanks again DOCZ for the great wheels!
Old Jun 8, 2011 | 09:58 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Here you go...
http://www.customcorvetteaccessories...weringkit.html
You can lower on the OEM bolts
or
get longer ones for the rear
You will need an alignment
Peace
Chip
__________________
..................Click for
Old Jun 8, 2011 | 10:13 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Are these tires shorter than the factory ones you removed?? ....From the pics it looks like they are ....You may have a speedo-issue unless you recalibrate the speedo...You may also experience an ABS issue if you changed the diameter from the front to the back vs the factory diameters.....Overall outside tire diameter should remain the same when doing a tire/wheel swap..
Old Jun 8, 2011 | 10:53 AM
dougbfresh's Avatar
dougbfresh
Go with wider sidewalls and leave the height alone. You'll get a better ride and you won't scrape all the time.
Old Jun 8, 2011 | 11:32 AM
Rob04C5LM's Avatar
Rob04C5LM
Lowering isn't that big of a deal, but if you've never done it before I suggest having a good shop that knows Corvettes give you a hand - you have to have it aligned afterwards anyways so you may as well.
If you do the stock bolts you need to trim the stops. However, I personally recommend getting a set of aftermarket bolts (less than $50) so that you have something that was meant to adjust that much.
The change in ride quality isn't as intense as I've had on other cars I've owned. The suspension just feels more "ready" now than it did before, I guess because it's pre-loaded. I don't scrape on much, just the plastic air dam occasionally when I go over high speed bumps, but you learn to approach steep driveways and speedbumps a bit more sideways than before.
Old Jun 8, 2011 | 12:04 PM
76 VETTE's Avatar
76 VETTE
Looks nice the way it is!
Old Jun 8, 2011 | 06:14 PM
The NNIAL8R
Originally Posted by DOCZ- 1st Rate Corvette Parts & Acc.
Car looks great. As long as you keep the rear diameters taller than the fronts then there will not be any issues with the active handling. Its almost imposible to keep the same diameters with the stock when going with a 18/19 or 19/20 with wider tires. C5 owners have been changing out there tire sizes since 1997, its nothing new.
Interesting....a local club member went with 19s & 20s with ultra low profile tires on her 2004 Convertible...Because of such it didnt retain the stock tire height.....She immediately started having serious ABS problems....Took it to the dealer as it was under warranty....They told her the incorrect tire diameters were confusing the computer....She replaced the ultra low profile tires with a set which had the same diameter as the factory tires...viola, no more ABS problems...
Old Jun 8, 2011 | 06:15 PM
The NNIAL8R
Yeah, if it was a 4x4
To How do you lower a car?
